585,938 active members*
3,188 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Ball Nose Upcut vs. Downcut
    Jun 2008
    36
    I was about to start doing some 3D cutting and needed some bits. I am seeing that I have options for Up and down cut. As long as I am doing a roughing cut first, does it really matter?
    Apr 2004
    5737
    Re: Ball Nose Upcut vs. Downcut
    Up-cut is standard, because it evacuates the chips. Down-cut is used when you're cutting plywood or laminates and want to avoid pulling up chips in the top veneer. If you're running a roughing pass first, that's not going to be an issue, so go with the up-cut bits.
    Andrew Werby
    Website
    Jan 2022
    Hello. As I know, ball nose spiral end mills are used for smooth contouring and fine detail passes with a CNC router and often for complex shapes like 3D carvings. These bits are also excellent for routing fluted columns and channels in cutting boards and countertops edges.
    krunkerio
    Mar 2023
    This post is very helpful to me because it gives me a lot of information. I always like to read good writing, and your post had that. Thank you for your help. Fun Games
  1. Using Ball Nose EM
    By Atomic_Sheep in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-08-2019, 10:10 PM
  2. Ball nose Bits
    By zmiller627 in forum CNC Tooling
    Last Post: 09-03-2013, 06:14 PM
  3. Bull nose or Ball nose
    By jcnewbie in forum Mastercam
    Last Post: 02-22-2010, 12:35 AM
  4. What type of ball nose to use?
    By gorby in forum CNC Tooling
    Last Post: 12-10-2009, 10:34 PM
  5. Ball Mills Vs. Round Nose
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 03-11-2008, 03:20 PM
