585,975 active members*
5,020 visitors online*
    May 2008
    77
    Z-axis position not holding after reboot.
    After shutting down at the end of the day and coming back the next morning I'm finding my last Z-axis height setting has not been retained. It has held through the entire previous day's work but after a shut down (typically overnight) and start up the next day I have to reset my Z0 position to the top of my material. It always seems to have moved about 2.5" up after the PC restart.
    Am I missing something in the setup of the system that tells it to save your last Z0 on shut down?
    Since I almost always start at the same X0,Y0 location I don't know if the same would happen there if I moved that further into the table.
    BH
    Feb 2012
    149
    Re: Z-axis position not holding after reboot.
    Quote Originally Posted by bhdavis1cnc View Post
    BH
    Do you have a 2.5" saved in the offsets? Do you home the machine after power on?
    May 2008
    77
    Machine gets HOMED on every startup or reboot of the system.
    I shouldn't have a 2.5" offset saved as I don't use any saved offsets. Good thought though. I'll double check to make sure.
    BH
  1. Aggregate rotation and position holding
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 05-29-2020, 04:29 PM
  2. Position loss after power reboot
    By Hector_Ta in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2016, 08:54 AM
  3. EMCO F1 CNC Mill Not Holding Position
    By Tech teacher in forum EMCO Mills
    Last Post: 05-04-2015, 02:41 PM
  4. Holding the position with an AC motor
    By svenakela in forum CNC Machine Related Electronics
    Last Post: 10-05-2013, 03:51 PM
  5. Not holding a zero position?
    By DerHammer in forum Fanuc
    Last Post: 01-11-2008, 05:29 AM
