585,670 active members*
4,329 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MX45VAE Will not move after startup
Results 1 to 10 of 10
    Feb 2021
    38
    Turned on machine ran through its checks all looks fine, press power on the control control fires up hydraulics same, but machine will not move. Hydraulics at pressure and oil, chiller the same, air same, no alarms. Cant run spindle or move table.. WTF something I'm missing??? Last time I ran it I pulled out the tool but I tried with it in and out.. Something I missed on startup?? any data needs to be entered?? buttons pressed??
    Apr 2009
    1262
    Re: MX45VAE Will not move after startup
    Is machine lock on? Axis inhibits on?
    Experience is what you get just after you needed it.
    Dec 2008
    3108
    Quote Originally Posted by OkumaWiz View Post
    Toolchange in mid cycle (not at start or tool staged position )
    rapid/feed rate override set to zero
    Residual move not yet complete (not after restarting)
    Jun 2015
    4154
    hy, sometimes the claws that grab the pullstud may remain too long in an intermediate position, because of a wrong toolchange sequence; this may be caused by missalingment, because of manual toolchange, or because of swing arm - atc - spindle alingmnent
    as a consequnce, the hydraulic will be up for for too long, over a preset timer, that will jump a fuse in the electrical cabinet
    if you can not clamp/unclamp tools, then look for this; besides this check, i have no other idea / kindly
    Mar 2009
    1982
    if the pannel is not locked try select the MDI mode and command, for instance S500M3. OSP should show some alarm message.
    Feb 2021
    38
    No not that I know of.
    Apr 2009
    1262
    Quote Originally Posted by Fireater View Post
    I think all if what is suggested is good to try...what have you checked so far?
    Also please reveal what sequence your tool changer is on. (Look in the ATC display page) It should be at sequence 1. If not, you will need to get it there like superman says. Also try Al's test and let us know the result.
    Best regards,
    Feb 2021
    38
    Not locked not that I know of. Panel responds as it should. no fuses I can see popped. I put in a tool change in MDI and you can hear it want to respond but no hydraulic movement. tool will grab if I put one in manually. I can move the tool changer arm through ATC cycles with the cycle buttons on controller so it moves. No alarms shown.... WTF.... any ideas?? procedure list or possible corrective options lists would be helpful to eliminate possibilities. Start up procedure.. Power on, control on, open/close door, Should be ready.. MDI T6M06 just sits there, cycle start just sits there, I can not move the head/table to move or get the spindle to run.
    Apr 2009
    1262
    If you let the control sit on the T6M6 and wait 3 minutes, what alarm pops up? Are the run, STM, lights on? If you go to block data and check the page are any of the codes blinking ON/OFF? Is the spindle orientation complete? When you try the MDI commands, what sequence # in the ATC page does it get stuck on? Is the door closed?
    BTW, I'm assuming it's a 5020M-G control, is this correct? Do you have the maintenance manual? If yes, the sequence for the tool changer is shown in there for your machine. Are you able to manually run it all the way through a tool change and back to sequence 1?
    Don't mean to shotgun you with questions, but rather give you clues to follow for troubleshooting.
    Best regards,
    Feb 2021
    38
    Thanks for the info. I have a OSP7000M control if that helps..
  1. MC-600VF I80m Intial startup won't move
    By ka67_72 in forum Uncategorised MetalWorking Machines
    Last Post: 01-16-2021, 10:14 PM
  2. Okuma MX45vae
    By angorgus in forum Okuma
    Last Post: 10-10-2020, 11:05 AM
  3. b axis -overflow mx45vae u100m
    By O-MX45VAE in forum Okuma
    Last Post: 11-01-2018, 07:22 PM
  4. Replies: 13
    Last Post: 04-28-2017, 05:28 AM
  5. Okuma MX45VAE Oil Chiller
    By wjjosep in forum Okuma
    Last Post: 07-26-2011, 10:25 PM
