585,744 active members*
5,272 visitors online*
    Laser beam wobble
    Help! I am new to lasers. This is an 80 watt red/black Chinese machine.
    Power level 9ma.
    Chiller temp 72 deg f
    What makes the beam wobble at the output end?
    thanks!
    Nov 2008
    644
    Re: Laser beam wobble
    I run my temperature at 62 deg F and 9 ma seams low for an 80 watt tube. But neither would make the beam wobble. Never heard that before, maybe the tube is going bad. Or there is a mechanical vibration in the machine.
  1. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  2. Replies: 0
    Last Post: 07-05-2016, 09:24 AM
  3. Laser beam runs on the outside of the laser tube!
    By dadde in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-18-2015, 03:19 PM
  4. No laser beam...
    By Laser Larry in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2013, 07:13 AM
  5. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
