585,880 active members*
7,463 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > AASD servo not reaching full rpm in speed mode.
    Sep 2009
    16
    I have a Chinese aasd servo drive and motor (80st-m04025) that i run on 110v in speed mode.
    My problem: even at full 10v input signal the motor only reaches 2000rpm Max.
    Also in manual jog mode it only reaches 2000rpm
    (Rules out input voltage issue)
    My parameters:
    Pn02: speed mode
    Pn159: 300 (should give 3000rpm at 10v input)
    Pn168: external analog voltage
    Is it because I run on 110v?
    Any suggestions are appreciated.
    Thank you,
    Rob
    Dec 2013
    5717
    Re: AASD servo not reaching full rpm in speed mode.
    Most likely there is a Maximum Speed parameter that is set to 2000 RPM.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    1516
    Quote Originally Posted by rschwarz View Post
    My parameters:
    Pn02: speed mode
    Thank you,
    Rob
    Check pulley settings in your cnc program also.
    15362
    My parameters:
    Pn02: speed mode
    Thank you,
    Rob
    Yes it could be 120v supply voltage, it will give you less RPM unless the Drive is rated /setup for that Voltage, the other thing to look at is the electronic gearing in the drive, ( if it has it ) this to can give you a low output if not set correct
    Mactec54
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. aasd-15a AC Servo Drive Tacho output ?
    By NoHope in forum Servo Motors / Drives
    Last Post: 12-26-2021, 02:55 PM
  3. aasd servo controller
    By zmcdona1 in forum Spindles / VFD
    Last Post: 10-04-2020, 10:05 PM
  4. NVEM V2 connect to AC SERVO DRIVER AASD-15A-V6.3
    By Josip_Skukan in forum Spindles / VFD
    Last Post: 08-01-2020, 08:00 PM
  5. Plunging before reaching proper RPM
    By aKruse in forum EnRoute
    Last Post: 11-11-2011, 05:26 AM
