585,733 active members*
4,661 visitors online*
    dnc for leadwell mcv 1000 ap
    Hello friends
    I have a leadwell mcv 1000ap device with fanuc o-m model f
    Produced in 1990
    In this device, the parameters can be transferred to the device and computer
    The G-code program can also be transferred to the device memory
    But it is not possible to send the program from dnc software such as cimco and run it by the device
    Thank you for your help
    Aug 2019
    145
    Re: dnc for leadwell mcv 1000 ap
    Do you see a "Tape" or "DNC" mode selection on the operators panel. The old membrane style panels were nearly impossible to re-label so it is possible an un-labeled button will select DNC/Tape mode.
    You can check the ladder for G127.5. This bit on (1) in conjunction with Auto mode places the control into DNC/Tape mode.
  1. Leadwell MCV-0
    By dpaulson in forum Fanuc
    Last Post: 01-07-2016, 07:39 PM
  2. help with Leadwell MCV-OP
    By prec-tech in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2011, 06:34 AM
  3. MCV-OP Leadwell????
    By bdrmachine in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2006, 02:35 AM
