585,728 active members*
4,696 visitors online*
Results 1 to 8 of 8
    Oct 2021
    4
    rznc controller
    Hi Everyone ! I have a laguna swift 2x3 and in attempting to speed up feed rate altered the "Z" settings and cannot get the machine working correctly again. I would greatly appreciate help with this as my shops been down over a week now and orders are piling up !! Laguna customer service hasn't been helpful. THANKS !
    Mar 2015
    409
    Re: rznc controller
    The first thing to do will be to reverse all changes, but I guess you have done that already!
    What is not working?
    What settings did you change
    Do you have a manual (link)
    Oct 2021
    4
    Re: rznc controller
    Hi The z movement is incredibly slow when using the touch off puck and not much faster when moving manually. It doesn't cut the depth as programmed and doesn't return to up limit when done. x,y speeds function are fine C>A>D> in controller is entered correct but when the puck is used it runs as if the top of the puck is the work surface.
    Mar 2015
    409
    Re: rznc controller
    Quote Originally Posted by mgilly View Post
    This could be due to a wrong (to high) step resolution (steps/mm). If you jog 1 mm, is the distance really 1 mm?
    Oct 2021
    4
    Re: rznc controller
    Thanks ! Would that be the Pulse/mm under Equivalent settings ?
    Mar 2015
    409
    Re: rznc controller
    Yes, that could be the setting
    Before you change it, note the old value!
    Oct 2021
    4
    Re: rznc controller
    Yes ! That was it. Machine is running perfectly now. Your help was just what I needed. Thank you Thank you !!!!!
    Mar 2015
    409
    Re: rznc controller
    Great to hear it is working again.
    It is safe to note all settings in case of a disaster.
    Looking at your machine, i expect it is already tuned at maximum performance.
    greetz, Huub
  1. DSP-controller (RZNC 0510
    By gricardo in forum Commercial CNC Wood Routers
    Last Post: 11-06-2020, 03:34 AM
  2. RZNC 501 controller issues
    By Syphonics in forum Controller & Computer Solutions
    Last Post: 04-11-2020, 06:51 PM
  3. Differences between DSP RZNC-D5416 and RZNC-0501
    By KDRusty in forum Chinese Machines
    Last Post: 06-04-2014, 10:06 PM
  4. rznc dsp controller
    By radicalrescue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-16-2013, 03:54 AM
  5. Chinese RZNC-05 controller & spindle help?
    By Metalmog in forum Commercial CNC Wood Routers
    Last Post: 05-25-2010, 05:20 AM
