585,973 active members*
4,130 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 10T TURRET SPEED SLOW DOWN?
    Sep 2009
    91
    Hi guys
    Can somehow slow down the rotation speed of my turret in parameters?
    Dec 2009
    953
    Re: FANUC 10T TURRET SPEED SLOW DOWN?
    if the turret is controlled by a servo motor can be done but we need more info about the type of Fanuc and info about the servo drive
    If the turret is controlled by a hidraulic motor you need to adjust the speed from the flow of the oil.
    Sep 2009
    91
    The Fanuc is FS10TF
    The turret is mechanical powered by small motor 0.4kw
    Quote Originally Posted by zavateandu View Post
    Sep 2009
    91
    Hi
    I solved the problem. Install frequent regulator and change the speed from 50Hz to 30Hz. Now the turret work slower but without any noise.
    Quote Originally Posted by tano View Post
    The Fanuc is FS10TF
    Hi
    That's clever.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Replies: 0
    Last Post: 11-24-2018, 07:16 PM
  2. Replies: 10
    Last Post: 12-19-2017, 04:42 PM
  3. Replies: 3
    Last Post: 06-06-2014, 04:55 PM
  4. Fanuc 10T Turret Rotation Problem
    By ehsan72 in forum Fanuc
    Last Post: 06-10-2013, 03:14 PM
  5. Replies: 0
    Last Post: 01-09-2012, 05:14 AM
