585,977 active members*
4,113 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Need help with calculating tool nose compensation
Results 1 to 3 of 3
    Hey guys, Im writing a CNC program (not a g-code) for a lathe machine and im having some trouble with calculating the tool radius compensation needed for arc cutting.
    When the arc angle is 90 degrees there's no problem, the problem is when i want to cut an arc that is less than that.
    Are there any formulas for calculating the compensation needed with dependece on the tool radius and the arc radius?
    Thanks!
    Jun 2015
    4154
    Re: Need help with calculating tool nose compensation
    hy can you join several 90 degress arches, that have different radius, and different centers, and are not tangent ?
    handling rad comp requires offseting and sometimes auxiliar geometry in between not tangent entities
    please share a bit more details, maybe an example, so to see exactly where you get stuck, and i will help you / kindly
    Mar 2009
    1982
    "calculated" tool path for 90°, covers the path for less, right? Just find the point of transition to the next shape element.
  1. Tool nose radius compensation on SL-3a
    By cheenky in forum Mori Seiki lathes
    Last Post: 12-10-2012, 08:49 PM
  2. Replies: 1
    Last Post: 09-21-2012, 08:21 PM
  3. Calculating the arc with tool nose compensation
    By myhäje in forum Mechanical Calculations/Engineering Design
    Last Post: 04-13-2012, 08:58 PM
  4. tool nose compensation problem
    By Matyi in forum Fanuc
    Last Post: 03-24-2008, 09:42 AM
  5. 6T - tool nose compensation
    By Bluey in forum Fanuc
    Last Post: 10-11-2007, 01:51 AM
