585,708 active members*
3,768 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Can I use only 1 bearing blocks per axis?
    Apr 2021
    8
    Hi all!
    My current machine's Y-axis saddle length is 137.5mm. The new linear guideway I'm installing on my machine comes with 124mm bearing blocks.
    The load-bearing specs of the new bearing block are more than enough to support the weight on my current Y-axis.
    Can I use only 1 bearing block to mount the saddle on?
    May 2018
    17
    Re: Can I use only 1 bearing blocks per axis?
    What size rails? A block that long is probably meant to be the only block on the rail, and may have two tracks of bearings per race, or just a much longer loop.
    Apr 2021
    8
    Quote Originally Posted by strostkovy View Post
    Yes, you are right on. 2 tracks of rollers per side. It's the Hiwin roller type series(RG series).
    I'll be installing the 25mm and 35mm rails. 35mms on the Y-axis.
  1. Mazak VTC200b X Axis linear bearing blocks
    By kentw in forum Maintenance DIY Discussion
    Last Post: 02-09-2017, 10:07 PM
  2. Source for Bearing in the BK12/BF12 Bearing Blocks
    By localguy65 in forum Open Source CNC Machine Designs
    Last Post: 01-03-2013, 01:27 PM
  3. Bearing Blocks.
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 08:41 AM
  4. Makeing bearing blocks
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 09-07-2009, 04:27 PM
  5. Skate Bearing Blocks?
    By thebluedirt in forum Linear and Rotary Motion
    Last Post: 02-08-2009, 02:59 PM
