585,748 active members*
3,424 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Auto tool change without adaptor
Results 1 to 7 of 7
    Dec 2006
    130
    Hi all, I am designing an automated robot grinding, the grinding process will be using lots of shaft mounted grinding tools, ie 15pcs per workpiece.
    Therefore I would like to design the auto tool changer without the need for an adaptor for each abrasives tool, to reduce the adaptor cost for each grinding tool.
    I have seen such tool change on the net, but I am not able to find more information on how it works or makers that does that.
    Tool shank: 3.15 or 1/8”
    RPM about 15K to 18K
    Dec 2013
    5717
    Re: Auto tool change without adaptor
    Can you provide a link to this being done?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2006
    130
    Hi, this is the link
    https://youtu.be/Ppjz26BM1KQ
    Dec 2013
    5717
    Ah, now I have an idea of what you want. Pretty simple, you only need a spindle that is set up for an ATC, and use the correct G and M code commands to accomplish the tool change.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2006
    130
    Hi Dawson, I do not require the NC codes, I will be using robot to do the grinding process. I am actually looking for such spindle that is able to grip the polishing tools without the need for adapter
    Dec 2013
    5717
    I think what you want is a dental ATC spindle.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by Syphonics View Post
    Your grinding tools / mandrel would need a pull-stud of some kind on the end, and the spindle would need to pull the grinding mandrel into the taper in the spindle
    Do you have some photos of your grinding mandrels, spindle.
    Mactec54
  1. auto tool change on axis A
    By vektor_z in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-18-2019, 01:30 AM
  2. Heidenhain M101 - Auto Tool Change If Tool Life Expires
    By Scott_1979 in forum G-Code Programing
    Last Post: 08-21-2018, 03:25 PM
  3. Auto tool change position
    By Tobione in forum Cincinnati CNC
    Last Post: 04-24-2018, 11:46 AM
  4. Replies: 3
    Last Post: 07-04-2011, 01:35 PM
