585,702 active members*
4,290 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper driver too powerful for motor
    Dec 2007
    I have an application that requires a very high resolution on the Z-axis that my current table top CNC milling machine cannot achieve. I plan to use a motorized stage from Thorlabs (scientific equipment): LNR25ZFS. I was hoping to just have to connect the stepper motor to the driver of my current Z-axis (Leadshine DM556E) but I think the driver might be too powerful for the motor. The driver specs state a min. output current of 1.8A and the motor is rated for 0.25A current per phase (see full motor specs here).
    Did I interpret the specs correctly? If I need to use a smaller driver, can someone recommend one appropriate for this tiny motor?
    May 2015
    686
    Re: Stepper driver too powerful for motor
    It did list a "required driver" so I think for the cost of the stages you would be better sticking to their driver But I don't think it will be suitable for normal CNC use. It looks like its a smart driver with S curve (jerk limiting) acceleration profiles built in which implies it is more for industry than CNC.
    Rod Webster
    www.vehiclemods.net.au
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
