585,970 active members*
4,093 visitors online*
    Oct 2009
    23
    Smile SST Knurled Shaft Collar - 500pcs
    Please quote 500pcs - reorders likely.
    303 or 304 - whichever is cheaper / easier to machine.
    1/2" bore can probably be drilled, but it needs an easy slide fit on an on-size 1/2" shaft.
    Looks like a Fine Knurl - will confirm and/or can provide a sample.
    It also looks like the diamonds are not sharp/complete is ok...
    Length tolerance -0.0 +.005
    OD knurl swell is no problem.
    Include ETA -
    Shipping to 37374 would be helpful
    Thanks for your interest,
    please contact:
    [email protected]
    Attached Files Attached Files
    Oct 2009
    23
    Re: SST Knurled Shaft Collar - 500pcs
    QUOTE IS CLOSED - THANKS TO ALL WHO RESPONDED
  1. Replies: 1
    Last Post: 09-14-2014, 07:20 PM
  2. Short run (500pcs) poss. laser or waterjet job
    By jrh_engineer in forum North America RFQ's
    Last Post: 08-25-2014, 03:16 AM
  3. Shaft collar backlash
    By saintpaul in forum Benchtop Machines
    Last Post: 08-07-2012, 11:27 PM
  4. knurled surface
    By larry53 in forum Autodesk
    Last Post: 12-28-2010, 03:25 PM
  5. RFQ - small knurled 'caps' for M2 SHCS
    By sierra4sport in forum Employment Opportunity
    Last Post: 04-14-2008, 04:22 AM
