584,863 active members*
4,944 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Engrave cylinder/Hemisphere?
Results 1 to 2 of 2
    Jan 2014
    17
    I'm looking for CAM software to replace my Autodesk stuff. Most any software is capable of most of the operations I do, except it would seem, engraving 3 dimensional surfaces.
    Is visualcam capable of engraving cylinders, tapered cylinders and hemispheres? I will be solid modeling the shapes and engravings using Alibre Design, and importing into CAM as a .stl file. Or, that is the intent anyway, since that's the way I've always done it with Inventor/HSM.
    Apr 2003
    1354
    Re: Engrave cylinder/Hemisphere?
    Yes, this should be possible. The 2 1/2 axis engraving toolpath is actually a 3-axis path. It will follow your curves. But I would avoid STL. If you're modeling it as a solid, then just use the STEP translator. VisualCAM will work with STL's, but it seems like an unnecessary step if you've already modeled it as a solid.
  1. Hemisphere on Tormach - InventorCam Help
    By dzavelson in forum Tormach Personal CNC Mill
    Last Post: 03-12-2013, 09:58 PM
  2. soft to engrave on cylinder
    By maximusek in forum Uncategorised CAD Discussion
    Last Post: 03-27-2012, 01:04 PM
  3. 3D milling of hemisphere
    By Indexschrotter in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-20-2008, 09:32 AM
  4. unwrap cylinder to engrave on o/d
    By Capt Crunch in forum Mastercam
    Last Post: 04-23-2007, 01:18 AM
  5. Hemisphere program
    By Captain Midnigh in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2006, 02:35 PM
