585,560 active members*
3,298 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Default Hydraulic oil flooding out the spindle b212 kitagawa chuck okuma lu15 impact
Results 1 to 9 of 9
    Nov 2021
    5
    hi guys i was wondering if you could help me? i have been running this machine with a 12" chuck for 1.5 years never had an issue with it the draw tube is practically new custom built
    all of a sudden out of nowhere the hydraulic oil starts pouring out of the spindle
    any clue as to what's going on? or what might have caused it? the machine is a 1999 LU15 Impact B212 kitagawa chuck
    thanks a lot
    Hydraulic leak from spindle - YouTube
    Dec 2008
    3109
    Re: Default Hydraulic oil flooding out the spindle b212 kitagawa chuck okuma lu15 imp
    Possibly a seal/o'ring gone on the drawtube.
    Remove lock ring and drawtube only to inspect. Should not need to remove chuck
    Nov 2021
    5
    Quote Originally Posted by Superman View Post
    how do you remove draw tube without removing the chuck ??
    you mean from the back?
    Apr 2006
    111
    Quote Originally Posted by kitagawa212 View Post
    Remove it from back
    Dec 2008
    3109
    You should have been supplied a tube type socket that has 2 tabs that fits the drawtube in the back end of the spindle. CCW to unscrew.
    Looking at your video, could you be using the chuckjaws set near the end of clamp stroke ? (Seal could be sitting on a pitted area allowing hydraulic oil to pass)
    Nov 2021
    5
    i could make that
    do you have a picture?
    you're talking about something like a spanner wrench for removing installing chucks ? but another one for removing actuators?
    Nov 2021
    5
    this site is so confusing one day i am on industryarena and then i am on CNC zone is it the browser? like firefox CNC zone ? Chrome = industryarena?
    Dec 2008
    3109
    i could make that
    This is only a pic.... may NOT fit your machine, paste the following into a browser
    https://www.ebay.com.au/itm/264650515538?chn=ps&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&itemid=264650515538&targetid=12791566290 93&device=m&mktype=pla&googleloc=9071480&poi=&camp aignid=9767741255&mkgroupid=122892480939&rlsatarge t=pla-1279156629093&abcId=578876&merchantid=494542272&gc lid=CjwKCAiA7dKMBhBCEiwAO_crFCuHP0-7Y37VU01r6E9hhCopsCXedsZ9C5_iOoPKj18ArAPU-19jcxoCtMsQAvD_BwE
    Apr 2009
    1262
    There are o-rings on the outside of the draw-tube, but they are for keeping coolant from getting into your spindle bearings. If you have a hydraulic leak, you most likely have an actuator seal failure or else a clogged/kinked drain tube from your actuator back to the hydraulic tank. The actuator always has a little blow-by around the piston and that is what the drain tube is for...letting the blow by drain back to the tank. Check for proper drainage thru the drain tube. If your actuator seals have gone, then it may be introducing hyd fluid into the ID of the actuator and thereby draining back through the draw-tube ID.
    Be careful, high pressure pin hole leaks can puncture the skin and fill it with hydraulic fluid. Not a good situation.
    Best regards,
    Experience is what you get just after you needed it.
