585,949 active members*
4,131 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese VFD and Mach3 usb
Results 1 to 10 of 10
    Hi
    Hope someone can held me with my limited electrical experience. I’m currently building a CNC router and have most of the parts. Started to build the electrics up and have got the 4 stepper motors working using Mach3 usb BOB. Then I got the 2.2 kw spindle working direct to the VFD. I have set up the twin relays for spindle rotation working. The problem I have is connecting the wires from the BOB to the VFD as the VFD terminals are not named VI, ACM or VR so unsure which terminal connects to the BOB. I have a 24 volt supply to the BOB along with USB feed just didn’t want to damage either the VFD or the BOB by connecting incorrectly.
    Mark!
    Attached Thumbnails Attached Thumbnails 67F8BB4A-5A1E-45EC-97DA-E9489CA3C302.jpg   40F7E891-CF71-4583-B3B6-F8FD7AE3312C.jpg   6C467ABD-99E1-48FB-8DB6-C35E9C35494B.jpg
    15362
    Re: Chinese VFD and Mach3 usb
    Quote Originally Posted by Spirebuddy View Post
    Hi
    Mark!
    You should only be using ( 1 ) Relay for your Spindle, the manufactures only recommend the FWD direction, for these spindles.
    VI and ACM connection is normally PWM to Analog 0-10 Volts, depending on the VFD Drive your one looks like it may be 0-5v. what is the model # manufacture of the VFD Drive.
    Mactec54
    The make is Isacon Power Control model series A2 8022
    Jan 2018
    1516
    Thanks for these. I have seen these before but still not sure which pin goes where on the VFD to control the speed. As pointed out above it should have a 10volt out to go to BOB but only shows a 5 or 12 so not sure if I can use these. Directions look straight forward. It my lack of knowledge on the terminology used.
    May 2010
    13
    Of coures you'll also need to change the VFD's parameter to look for the correct input.
    These files show the breakout supplying the 0-10v speed signal
    http://shoelessdave.com/Vancura.Inno...0wjv%202.2.pdf
    On page 13 of the pdf
    https://drufelcnc.com/doc/DrufelCNC_BSMCE04U_manual.pdf
    Jan 2018
    1516
    Quote Originally Posted by MarshaJ847 View Post
    That's the one I was trying to find earlier.
    AV1 = Analoge Voltage 1. (0-10v).
    ACM= Analoge Common.
    Quote Originally Posted by dazp1976 View Post
    So which are these on the VFD from the board as ACM and AVI are marked on the board but not on the VFD is it the 10 Volt in and the GND?
  1. Mach3, Sunfar VFD, and Chinese 5-axis BOB
    By Ceramic Man in forum Spindles / VFD
    Last Post: 08-11-2022, 04:40 AM
  2. Replies: 28
    Last Post: 07-23-2020, 09:30 AM
  3. Replies: 3
    Last Post: 02-15-2020, 09:33 PM
  4. Mach3 - ESS smooth stepper - Huanyang Chinese VFD - Mach 3 e-stopping???
    By Chris D in forum Mach Software (ArtSoft software)
    Last Post: 05-29-2019, 11:59 PM
  5. Huangyang VFD YM-800A inverter - USB mach3 control board
    By Dhann73 in forum Machines running Mach Software
    Last Post: 07-29-2017, 06:51 PM
