586,009 active members*
4,826 visitors online*
    May 2016
    16
    Air op conversion
    I finally got off my butt and completed my air op conversion on my machine. Mounted a shortened 2 stage air cylinder without drilling a single hole in the machine. Manufactured supports with 2 diagonal having support blocks above and below z axis. Brackets below z axis prevent any possibility of support spread. All steel parts TIG welded. Control valve is mounted to small steel plate bolted to trailer light magnet. It's massive overkill on support but leaves easy accessibility to everything.
Name:	control valve.jpg
Name:	spindle bracket.jpg
    Attached Thumbnails Attached Thumbnails control valve.jpg   spindle bracket.jpg   control valve.jpg   spindle bracket.jpg
    Nov 2011
    38
    Re: Air op conversion
    I see the new machines have the power drawbar as a standard feature plus a BT 30 spindle- nice upgrades .
  1. Replies: 0
    Last Post: 04-06-2017, 12:38 AM
  2. Replies: 0
    Last Post: 03-20-2017, 08:31 PM
  3. CNC Air Spring Conversion
    By cce1911 in forum Benchtop Machines
    Last Post: 06-08-2012, 05:07 PM
  4. Gas engine to gas air compressor conversion
    By Tom Brown in forum I.C. Engines
    Last Post: 09-19-2006, 07:58 AM
