585,997 active members*
5,156 visitors online*
Results 1 to 3 of 3
    Sep 2009
    8
    Heidenhain 426M software
    I have an milling machine, DMC 100v with Heidenhain 426 M
    NC : Software 280474 15
    My harddrive BROKE, AND I GOT NO BACKUP :-(
    Is there a freindly soul, who have had the software for TNC 426M, i could get a copy of
    Apr 2019
    6
    Re: Heidenhain 426M software
    You need a working hard drive.
    You can use the controller to format the hard disk:
    Press and hold the MOD button when turning on.
    Select formatting from the menu.
    When done, the HEIDENHAIN system must also be installed.
    You can download it from HEIDENHAIN at this link:
    https://product.heidenhain.de/JPBC/i...C/28064115.zip
    When you're done, all you need to do is get the original backup from the machine tool builder ...
    You can use TNCremo to reload:
    https://product.heidenhain.de/JPBC/i...Cremo33428.zip
    Always back up your machines! TNCremo can help you with this as well.
    May 2020
    9
    Quote Originally Posted by csaky67 View Post
    Hi! does this also apply to LE430M? when booting up, holding MOD will enter boot mode for diagnosis? I am having similar problem, my backup floppy are corrupted, no matter what I do with ddrescue on linux, I still got corrupted .bck file which is compressed, then, hard to decompress manually, tncback x.BCK G does not regenerate back the ,LST file as it is corrupted...
    Now I got a pair of PATA SLC CF, mine uses 2.5 HDD, so with a adapter, it fits well into the TNC430, should I format it on FAT16, or let the controller format it, then add files later?
    Thanks!
  1. Help needs in haidenhain TNC 151
    By moghul in forum Bridgeport Machines
    Last Post: 08-09-2021, 11:29 PM
  2. Dmc 63v tnc 426m
    By EdikMavlo in forum Milling
    Last Post: 10-21-2018, 02:10 PM
  3. Haidenhain 410PA
    By Edvardas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2016, 09:43 AM
  4. Haidenhain itnc530
    By cshas3 in forum Solidworks
    Last Post: 02-08-2012, 03:29 AM
  5. Machine Software backup for TNC_407 Haidenhain
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 09-28-2009, 06:50 PM
