Here's what the final machine will look like.
I had to abandon building it on a 1200x800x120mm granite plate. The weight of the thing was 350kg and I do not want to risk having it brake in half if the guys drop it while transporting it to the 2nd floor, one guy slips and its over.
Moving from aluminum inserts to steel. I wanted to use aluminum plates and glue them with moglice to the blocks initially but once I computed how much of it I'd need I had arrived at the same cost as steel inserts.
I will use marking blue, a 4um straight edge and a hand grinder to get the inserts to desired flatness without a reference plate. If that won't work(as in takes too much time)I'll get a 800x500 granite plate as both the bed and reference. Fingers crossed I won't need it. Regardless, the bed will be 2 piece. Not sure about the front mounting plates on the bed yet.
Size 25 rails, narrow carriage CG series from hiwin(same price as HG but load and stiffness rating of RG), size 20 or 25 ballscrew with 5 pitch. Travels 420X 280Y 280Z. Total weight approx. 600kg
anyway have a look yourself :
https://www.mediafire.com/file/emc1d...ca/be.stp/file
