585,938 active members*
3,682 visitors online*
Results 1 to 16 of 16
    Apr 2008
    49
    Max spindle speed
    I have a captain 2007 L370 with osp-p200l control I recently change the chuck on. Went from a Kitagawa BL210 to a B-210. This B-210 is rated at 4200 RPM and the machine user parameter (allowable chuck rotation speed) is set at 3800. I get (error 5256 input data overflow Input: 1 ... 3800).
    Aug 2011
    419
    Re: Max spindle speed
    Maximum allowable spindle speed parameter isn't related using chuck.
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hy don't spin a large chuck at high revos for long; reason why there is such a high rpm limit, even on bigger series like 4000, is it to deliver torque at normal/common rpm ranges; thus spindle it is designed to perform best at middle ranges, not to be puhed
    spindle's acc decreases a lot once you put a chuck on it, yet it is still fast
    if i need, for example, to center drill at rpm > 2000, i swtich to live tools
    power consumption with reving high is signifiant
    for 10" on a2-6/8, i don't go over 2000
    is not common to need to reach 4000rpm with a 10"chuck; if you need high rpms, then most likely you need a smaller lathe, or at least use a smaller chuck ( even for your actual 3800, if used frequently and worth it ) / kindly
    Mar 2009
    1982
    I still don't get the initial question.
    The massive chuck makes a big difference on spindle acceleration/ deceleration. And first of all, the jaws are pulled out stronger with rpm increase. centrifugal force compensating chuck
    Apr 2008
    49
    Quote Originally Posted by Algirdas View Post
    I would like to move the limit from 3800 to 4200 and I get the error seen in the attached photo when I try. Is there another parameter else where?
    Jan 2018
    1516
    Quote Originally Posted by 1320feet View Post
    It is likely it is fixed there because that is at the maximum rpm of the actual spindle motor iitself. Has nothing to do with just a chuck,
    Apr 2008
    49
    Quote Originally Posted by dazp1976 View Post
    The machine has a 4500 RPM limit in its specs from Okuma.
    Jun 2015
    4154
    hy what spindle nose is there ? a2-6/8 ?
    Apr 2008
    49
    Quote Originally Posted by deadlykitten View Post
    Why?
    Dec 2008
    3109
    There may be another parameter, maybe one that controls gear ranges that has to be altered before trying to adjust User Parameters.
    You are good to question / ignore those other irrelevant queries, they have no bearing on your issue.
    I will suggest that using a higher max RPM will require higher acceleration/deceleration rates which could affect machine components, a greater chance of fatigue
    Jun 2015
    4154
    Why?
    hy i found both 3800 and 4500 for a2/6
    documentation release is generally delayed; is possible that what you saw was a typo
    okuma has special functions and parameters related to chuck weight and acc/decc for all axis ( linear or rotary , feed or rapid ) , but not through system variables
    depending on region, acces to them may be block by regulations, before shipment / kindly
    Jan 2018
    1516
    Coud've been when originally built. Then they may have backed it off later on after replacing too many chucks under warranty but not reprinted specs. Thus setting the peramiter at a fixed point so it can't be put back to spec max.
    Your original chuck was likely rated more than 3800 as well.
    Apr 2008
    49
Name:	b210 rpm limit.jpg
    - - - Updated - - -
Name:	okuma RPM tag.jpg
ID:	472470Click image for larger version.
    Jun 2015
    4154
    hey, most data from metalic label is generic, thus it is not about your machine only
    that label is bolted on any machine, as long as machine configuration is on the list
    your configuration is 3, as stamped at the bottom; all the rest of configurations may not be compatible with your machine
    please observe that, as stated on line 3, your spindle nose is a2-8, while lines 1 & 2 are for a2-6
    okuma does not craft chucks and hydraulic cilinders, nor toolholders or live centers; when you buy a machine, such parts are accesories, and are quoted separately; machine is being sent from japan without them, and they may be installed by your regional center ( according to dealers specification ), then machine is shipped to your location
    accesories as chuck and cilinder are mostly delivered by kitagawa, so this is why such metalic labels exist, as to show not only parity, but the strong relation between okuma and kitagawa; why would someone otherwise print such metalic templates ? why they don't exist for toolholders ?
    even so, lately, not all such parts are from kitagawa:
    ... maybe someone wishes for a custom brand
    ... maybe there are cheaper alternatives; for example, is not hard to craft chucks that are kitagawa's replica / kindly
    Jan 2018
    1516
    - - - Updated - - -
    Ok. So there is a B-210 there. (original one yes?)
    Ok. My guess is it's chuck number 3 which states 3800 on the plate.
    Ergo Your machine was LOCKED at 3800 by manufacturer for chuck #3.
    If you're adamant you want more speed then stick a bigger drive pulley/gear on the motor.
    Apr 2009
    1262
    There are both standard bore and big bore spindles for your machine. They have different max speed ratings regardless of the chuck. You can set them lower than max for the spindle but not higher.
    Check your bore… you’ll find you have the big bore spindle with the lower max rpm I’m betting.
    Experience is what you get just after you needed it.
  1. spindle speed fluctuations and not max speed
    By hociSK in forum Spindles / VFD
    Last Post: 09-20-2021, 12:08 AM
  2. Default Max Spindle Speed
    By rckdef in forum BobCAM for SolidWorks™
    Last Post: 12-30-2013, 05:46 PM
  3. Setting Max Spindle Speed ST-20
    By jheers in forum Haas Lathes
    Last Post: 10-17-2012, 10:11 PM
  4. Max spindle speed Tsugami BW-07
    By LATHEGIRL in forum Fanuc
    Last Post: 05-31-2012, 10:50 PM
  5. What max spindle speed should a mill have ?
    By nashtm in forum Benchtop Machines
    Last Post: 08-05-2005, 08:26 PM
