585,949 active members*
4,418 visitors online*
    Nov 2021
    Shopsabre cnc makes a bad 3d gorve
    Hi we are having problems with our shopsabre pro 408 cnc Its making some pretty bad ridges in a 3d cut we are making.
    Also we have the same problem when it cuts around a corner we get ridges. Ill try to attach some pictures. I was wondering if anyone else had these problems
    or if something is wrong with the code.
    Attached Thumbnails Attached Thumbnails 20211109_101548 (2).jpg   20211109_195137.jpg
    Nov 2021
    Re: Shopsabre cnc makes a bad 3d gorve
    Sorry about the pics they're a little hard to see. It seems to do fine on a straight run but when it gets to a circle or corner it starts to make ridges.
    Sep 2022
    Have you found out why the cnc is leaving these grooves in the stock? We are having the same issue on our IS510 and it leaves an uneven finish around corners.
    It seems like you can lower tolerances or increase smoothing in the program to fix the issue but I was wondering if you found something in particular that needs to be done for your machine for it to not leave the grooves.
    Jun 2007
    I’m a newby but It could be your CAD. I know in my system you can set the smoothness of the curves it creates.
    Quote Originally Posted by Jchm View Post
    This type of problem could be caused by many things, with ShopSabre purchases we offer some of the best support in the industry.
    It is always best to reach out to our direct support team versus looking for generic answers on the internet.
    Our team is available by email, phone, or web connect.
    Please reach out to us by visiting https://www.shopsabre.com/support/ with your contact information and one of our CNC support techs will be in touch to help you resolve the concern.
    Thank you
    ShopSabre CNC
    952-461-4570
  1. Florida ShopSabre CNC owners
    By dedvyned in forum Shopsabre
    Last Post: 11-02-2023, 02:31 PM
  2. LATEST VIDEOS - ShopSabre CNC
    By ShopSabre in forum Shopsabre
    Last Post: 11-04-2017, 02:42 PM
  3. What CNC Router to Buy? Weeke, ShopSabre, Used or New etc.?
    By MakeItRight in forum Want To Buy...Need help!
    Last Post: 10-15-2016, 02:18 AM
  4. Bridgeport BTC Boss 7 Really as bad as this thing makes it sound: See link
    By 777funk in forum Bridgeport / Hardinge Mills
    Last Post: 01-01-2010, 01:08 AM
  5. The NEW ShopSabre CNC! Fastest and most Powerful CNC under $100k
    By ShopSabreCNC in forum News Announcements
    Last Post: 01-11-2008, 01:10 AM
