585,951 active members*
3,866 visitors online*
Thread: power supply
Results 1 to 6 of 6
    Sep 2010
    54
    Question power supply
    Years ago I got a cheap SMC1800-50V-33A power supply. The power supply has an output of 50.5V. My CL57T controllers (3 pieces) are designed for 24-48v.
    Will 2.5v more be too much for my controllers?
    Jan 2018
    1516
    Re: power supply
    Yes.
    Does your supply have a little adjusting screw to lower it a little?.
    If not:
    Either change to CL86 drivers
    Or
    Get a new supply such as:
    https://www.aliexpress.com/item/1005...50529870%22%7D
    https://www.aliexpress.com/item/4000...25617994%22%7D
    There are loads of different options on the site. I have 80v, 60v, & 36v supplies from there.
    Mind you. Do you really need as much as 33A for 3 drivers?.
    You'd still be extremely comfortable with 48v 1000w.
    In which case I would find one of the adjustable voltage units in your input range and run it at 45v.:
    https://www.aliexpress.com/item/4000...c00uog8Pk&mp=1
    Sep 2010
    54
    Re: power supply
    I found a trimmer on the front panel and will try to lower the tension. I got this power supply years ago for little money. Back then, the prices of power supplies with such power were expensive. I also need to train my cnc because I have some work to do and the wait from China takes me too long.
    Sep 2010
    54
    Re: power supply
    Unfortunately, the trimmer drops the voltage only to 49.96V.
    Re: power supply
    Quote Originally Posted by kunte View Post
    Better find a new suitable power supply.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Sep 2010
    54
    Re: power supply
    I have already ordered via ebay 48v 10.4A for € 64.68. I already have the same. I will connect 2 CL57T controllers to each, and another CL57T and Leadshine DM556 to the other. For XYZ axis I have Nema 24 stepper motors 24HS40-5004D-E1000 4Nm 5A, for 4 axis so I have Nema 23 , 24H290-42-4 3Nm 4.2A
  1. Replies: 1
    Last Post: 01-12-2017, 07:12 AM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
