586,000 active members*
4,991 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Anilam 6000M losing tool table and tool changer position - HELP
Results 1 to 3 of 3
    Jul 2016
    I have had a Kent JM450 CNC mill for a number of years and it has run very well until recently.
    If I let the mill sit, power off, for an extended period (around 30 days) when I boot it back up the tool table is gone and the tool changer loses its position (call T6 and end up with T2).
    If I reenter all of the tools and manually re-index the tool changer (take the servo motor out and move the changer to the correct location) everything works great. I can shut down and reboot and everything is still there. It is only when shut down for long periods that I have a problem.
    Question 1: Has anyone else had this issue and what is the fix?
    Question 2: Is there any way to re-index the tool changer in software instead of manually moving it?
    Any help would be very much appreciated. This is getting old fast :-(
    Mar 2023
    Re: Anilam 6000M losing tool table and tool changer position - HELP
    Hi Just wondering did you find the problem with this ?
    Oct 2023
    5
    Quote Originally Posted by Turbinecopter View Post
    Did you ever solve the problem I have to Anilam 6000m tool changer codes to reset the carousel
  1. Tool changer out of position scm record 220
    By Benaiah in forum Commercial CNC Wood Routers
    Last Post: 01-28-2024, 01:55 PM
  2. FA630 tool changer out of position
    By ATSATHENS in forum Toyoda
    Last Post: 02-08-2022, 03:21 PM
  3. Y Axis position issue on a Fryer MC-60 Anilam 6000M Controller
    By Fonzi in forum Controller & Computer Solutions
    Last Post: 09-10-2015, 02:28 PM
  4. ANILAM 6000M tool change corrector problem!
    By Shishkinnick in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2014, 04:13 PM
  5. Replies: 9
    Last Post: 03-22-2008, 05:44 AM
