0 active members*
4,653 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2021
    25
    VFS5 NOT READY
    When the drives are turned on, the LED on the VFS5 flashes 5 times. + - 18 volts available 10 volts available.
    MOTION LINK IN TERMINAL ERROR 83 AND 84
    1.Sabre1000 machine
    2. No wiring diagrams!
    Mar 2011
    463
    Re: VFS5 NOT READY
    1) if I'm remembering correctly, error 83 and 84 are typical of what I see when someone unfamiliar with Motionlink uses it and enters invalid commands so they may not be related to your issue. It is also normal to see err 14 power bus and drive powered up messages, but since it only stores the most recent codes, these may have been pushed off the list.
    2) You can get the wiring diagrams from Fives, they will want the diagram number on the serial number plate. These won't likely help much with the current VFS5 issue, but it is always better to have them when working on a machine.
    Nov 2021
    25
    Re: VFS5 NOT READY
    Can anyone help with the wiring diagram?
    My electrical cabinet number
    91203230
    Thank you!
    Nov 2021
    25
    Re: VFS5 NOT READY
    Our fan crashed on VFS5.
    vfs5 monitors the presence of a fan?
    Is it possible temporarily without a fan?
    Dec 2006
    584
    Re: VFS5 NOT READY
    When the light flashes it is because of a bad battery, contact kilroy corporation , kilroycorp.com ???
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Nov 2021
    25
    Re: VFS5 NOT READY
    The LED is not blinking now.
    When all voltages are switched on:
    + 10v
    + -18v
    + 24v on c2 pin 6.9
    jumper on S7 MOTION, LIMIT
    And on PSR4 / 5
    Shines:
    sys ok
    Cpu
    FAULT
    RELAY
    AKTIV NO!
    I checked the resolver with 18om, 18om, and 36om
    On TERMINAL (Motion Link) when you enter EN (ON), appears
    ERROR 83 ...
    AND ALL
    What else can I check?
    Nov 2021
    25
    Re: VFS5 NOT READY
    now shines when voltage is applied
    ACTIV
    CPU blinking unpleasantly
    How to do autoload correctly?
    Nov 2021
    25
    Re: VFS5 NOT READY
    CPU blinks continuously
    Nov 2021
    25
    Re: VFS5 NOT READY
    Nov 2021
    25
    Re: VFS5 NOT READY
    It is now detected when the voltage is switched on
    ERROR 27 ”R / D JUMPERS” SEVERITY 3
    Either the jumpers on your BDS5 MC2 card are incorrectly set or the wrong
    TL has been loaded. Contact the factory.
    What to do with it?
    Nov 2021
    25
    Re: VFS5 NOT READY
    Who has a TL file on VFS5?
    Nov 2021
    25
    Re: VFS5 NOT READY
    There are instructions for creating a VFS5 spindle drive configuration?
    Or is MOTION LINK + enough !?
    Who can I ask questions?
    Nov 2021
    25
    Re: VFS5 NOT READY
    Does the forum work or not?
    Nov 2021
    25
    Re: VFS5 NOT READY
    How can I see anything from the configuration in MOTION LINK TERMINAL?
    What are the commands?
    Nov 2021
    25
    Re: VFS5 NOT READY
    Only ON, EN works in the TERMINAL.
    Other commands don't work!
    What am I doing wrong?
    Mar 2008
    285
    Re: VFS5 NOT READY
    I think you need to have the VFS5 Drive Repaired; they will replace bad Capacitors; RTC-Clock Chip with internal Battery and reload the Spindle Program and STD variables. User Variables are setup for the particular Machine Type and Spindle Gear Ratios and MAX RPM. The Rectangular Chip on the Front Top tells them what to reload. We quote Inspect and advise 1-800-534-4750 (Fives-Cincinnati-Repair Group )
    Nov 2021
    25
    Quote Originally Posted by maver1ck View Post
    what are the correct commands for MOTION LINK?
    some examples please ...
    Nov 2021
    25
    Re: VFS5 NOT READY
    What commands can I use in TERMINAL?
    Mar 2008
    285
    Re: VFS5 NOT READY
    --> ERR HIST (then Enter will display your error History)
    You do not have the tools to reload the VFS5 Program and Variables.
    For Inspect and advise quote contact 1-800-534-4750 (Fives-MSI-Cincinnati-Repair-Group)
    A neat reference site is (KOLLMORGEN BDS4/5 – CNC_Principle_Repair) unsecure
    Nov 2021
    25
    Re: VFS5 NOT READY
    err 18 line 246 "EN" BAD TL
    what to do about this error?
    Is this error both hardware and software?
Page 1 of 2 12
  1. VFS5 Kollmorgen drive
    By juniormachinist in forum Cincinnati CNC
    Last Post: 05-27-2022, 08:23 AM
  2. Koolmorgen VFS5 questions
    By bertcnc in forum Cincinnati CNC
    Last Post: 09-28-2016, 05:16 PM
  3. VFS5 FAN
    By Muggins in forum Cincinnati CNC
    Last Post: 05-02-2016, 06:26 PM
  4. VFS5 software
    By jacquestek in forum Cincinnati CNC
    Last Post: 10-05-2011, 01:57 PM
  5. Please help me. VFS5
    By udom in forum Cincinnati CNC
    Last Post: 06-21-2011, 08:26 PM
