585,748 active members*
3,400 visitors online*
Thread: Modbus
Results 1 to 16 of 16
    Mar 2017
    1304
    Modbus
    Mk3 controller always had support for transmitting Modbus commands.
    New Mk3/4 and Mk3 controllers with red 10pin connector also support receiving Modbus responses.
    We are developing new sets of commands that will greatly simplify Modbus usage.
    Does anybody use Modbus or wans to use it? What kind of devices do you have? Do you need master or slave implementation?
    Aug 2020
    131
    Re: Modbus
    I know that the linux cnc people like to use Modbus to control the VFD for the spindle.
    This typically makes the 0-10V converter board obsolete. Makes for a better, more consistent RPM setting and could perhaps also provide feedback from the VFD to Planet for status reporting.
    However this needs to be a quiet close integration into the S command to be beneficial, don't know how easy this can be achieved. (can the S command scripted by the user at the moment?)
    While I have a modbus capable VFD (Omron MX2) I don't see the need personally at this point in time as I have everything setup in a working order. However I think proper Modbus support could be a selling point for people who are looking for a new system.
    May 2020
    70
    Re: Modbus
    Hello,
    Interesting, I develop and use Modbus applications but for controlling temperature regulators.
    Many VFD use the Modbus protocol.
    Unless I am mistaken, I have never seen any presentation, possibility or example of the use of this protocol with MK3. Would it be possible to get some?
    My MK3 controller does not have a red 10pin connector, is it compatible?
    For my part, I would rather see the implementation in master mode, at least initially. The slave mode would imply having a system above to communicate, analyze, control TNG V2, which would be rather rare in the majority of our cases.
    if you are using a 10 pin connector i am assuming you are only using modbus RTU or ASCII, are you planning to implement modbus TCP?
    Feb 2021
    Re: Modbus
    Quote Originally Posted by PlanetCNC View Post
    My Mk3 board also don't have 10pin red connector (about 1 year old now). I think I will stick modbus but I'm more intrested about Ethercat any implemention plans
    Mar 2017
    1304
    Re: Modbus
    With new version write single coil (5) command can be sent like this:
    Code:
    (array,3000,0x11,0x05,0x00,0x00,0x01,0x00)
    (crc16,3000)
    M65 H0 Q3001 E#3000 R4001 D-1
    State of single coil (1) can be read like this:
    Code:
    (array,3000,0x11,0x01,0x00,0x00,0x01,0x00)
    (crc16,3000)
    Returned data count is stored in parameter 4000, results are in 4001, 4002,...
    It can be printed to output window like this:
    Code:
    (print,-----)
    (print,0x#<4000,-2>)
    (print,0x#<4001,-2>)
    (print,0x#<4002,-2>)
    (print,0x#<4003,-2>)
    (print,0x#<4004,-2>)
    (print,0x#<4005,-2>)
    (print,0x#<4006,-2>)
    (print,0x#<4007,-2>)
    (print,0x#<4008,-2>)
    (print,0x#<4009,-2>)
    (print,0x#<4010,-2>)
    (print,0x#<4011,-2>)
    (print,0x#<4012,-2>)
    Old Mk3 without red connector can send commands via TX pin.
    Aug 2020
    131
    Re: Modbus
    is this working with the mk3/9 controller as well?
    Mar 2017
    1304
    Re: Modbus
    Yes, Mk3/9 is just another name for Mk3.
    When I receive some Modbus devices I'll create more examples.
    Have you made anymore examples? I'm very interested in
    Controlling our VFD via modbus if possible.
    Is there any further documentation of the Api ect... that
    Isn't currently shared on your website?
    Frank
    Spark Robotic
    Re: Modbus
    The current G-Code documentation does not say anything about RX for M65
    M65 - Output TX
    Usage: M65 Q - Q = data send to TX
    M65 Q E - Q = parameter number of first data location
    - E = data count
    Send data to TX.
    M66 - Output I2C
    Usage: M66 H Q - H = I2C address in 8bit mode
    - Q = data send to I2C
    M66 H Q E <R> <D> - H = I2C address in 8bit mode
    - E = data count
    - R (optional) = parameter number for returned data
    - D (optional) = returned data count
    Send and receive data from I2C
    Frank
    Spark Robotic
    Re: Modbus
    Here is a python example of what we would like to control via either your serial out or a stand alone USB-RS485 converter.
    https://github.com/drogenlied/pyHYControl
    Any guidance would be appreciated.
    Frank
    Spark Robotic.
    Mar 2017
    1304
    Re: Modbus
    Latest G-code manual states:
    M65 - Output Serial
    Usage: M65 H Q - H = Serial port (0 or 1)
    - Q = data send to serial interface
    M65 H Q E <R> <D> - H = Serial port (0 or 1)
    - E = data count
    Send data to serial interface.
    I know it is not much but it is something.
    We will create much more tutorial, examples and also hardware for Modbus. Currently I only have some routines for relay board
    Modbus RTU 8ch relay module RS485/TTL UART 8CH input 8CH out_chinalctech
    mb_addrread.gcode - read board address
    Code:
    (print,mb_addrread:)
    #<len> = 7
    (array, 3000, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01)
    (crc16, 3000)
    (arrclr, 4000, 16)
    ;o<mb_printdata> exec [3000]
    M65 H1 Q3001 E#3000 R4001 D#<len>
    o<mb_printdata> exec [4000]
    o<mb_check> exec [3000] [4000] [#<len>]
    o<rc> if[#<_result> NE 0]
      M99
    o<rc> endif
    #<addr> = #4005
    (print,  address read: #<addr>)
    (print,--------)
    M99
    mb_addrwrite.gcode - write board address
    Code:
    (print,mb_addrwrite: #1)
    #<len> = 11
    (array, 3000, 0x00, 0x10, 0x00, 0x00, 0x00, 0x01, 0x02, 0x00, 0x00)
    #3009 = #1
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    #<addr> = #4009
    (print,  address write: #<addr>)
    (print,--------)
    M99
    mb_baudread.gcode - read current baudrate
    Code:
    (print,mb_baudread:)
    #<len> = 7
    (array, 3000, 0x00, 0x03, 0x03, 0xE8, 0x00, 0x01)
    #3001 = #1
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    #<baud> = #4005
    o<chk> if[#<baud> EQ 2]
      #<baudnum> = 4800
    o<chk> elseif[#<baud> EQ 3]
      #<baudnum> = 9600
    o<chk> elseif[#<baud> EQ 4]
      #<baudnum> = 19200
    o<chk> endif
    (print,  baud rate read: #<baud>, #<baudnum>)
    (print,--------)
    M99
    mb_baudwrite.gcode - set new baudrate
    Code:
    (print,mb_baudwrite:)
    #<len> = 8
    (array, 3000, 0x00, 0x10, 0x03, 0xE9, 0x00, 0x01, 0x02, 0x00, 0x00)
    #3001 = #1
    #3009 = #2
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    #<baud> = #2
      #<baudnum> = 4800
      #<baudnum> = 9600
      #<baudnum> = 19200
    o<chk> endif
    (print,  baud rate write: #<baud>, #<baudnum>)
    (print,--------)
    M99
    mb_check.gcode - helper routine for checking response
    Code:
    ;check length
    o<chk> if [#[#2] NE #3]
      (print,ERROR: expected length #3)
      #<_result> = 1
      M99
    o<chk> endif
    ;check response
    o<chk> if[#[#1+1] NE #[#2+1]]
      (print,ERROR: unexpected response address)
      #<_result> = 1
      M99
    o<chk> endif
    o<chk> if[#[#1+2] NE #[#2+2]]
      (print,ERROR: unexpected response command)
      #<_result> = 1
      M99
    o<chk> endif
    ;check crc
    #<crc11> = #[#2+1+#[#2] -2]
    #<crc12> = #[#2+1+#[#2] -1]
    #[#2+1+#[#2] -2] = 0
    #[#2+1+#[#2] -1] = 0
    #[#2] = [#[#2]-2]
    (crc16, #2)
    #<crc21> = #[#2+1+#[#2] -2]
    #<crc22> = #[#2+1+#[#2] -1]
    o<chk> if[[#<crc11> NE #<crc21>] OR [#<crc12> NE #<crc22>]]
      (print,ERROR CRC is 0x#<crc21,X>#<crc22,X>, expected 0x#<crc11,X>#<crc12,X>)
      #<_result> = 1
      M99
    o<chk> endif
    #<_result> = 0
    M99
    mb_printdata.gcode - helper routine for printing data
    Code:
    (print,Data @ #1: #[#1] bytes)
    #<cnt> = 0
    o<loop> while[#<cnt> LT #[#1]]
      #<val> = #[#1+1+#<cnt>]
      (print,  #<cnt>: 0x#<val,X>)
      #<cnt> = [#<cnt>+1]
    o<loop> endwhile
    M99
    mb_relay.gcode - set relay on/off
    Code:
    (print,mb_relay:)
    #<len> = 8
    (array, 3000, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00)
    #3001 = #1
    #3004 = #2
    o<chk> if[#3 GT 0]
    #3005 = 255
    o<chk> else
    #3005 = 0
    o<chk> endif
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    (print,--------)
    M99
    mb_relayalloff.gcode - set all relays to off
    Code:
    (print,mb_relayalloff:)
    #<len> = 8
    (array, 3000, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x08, 0x01, 0x00)
    #3001 = #1
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    (print,--------)
    M99
    mb_relayallon.gcode - set all relays to on
    Code:
    (print,mb_relayallon:)
    #<len> = 8
    (array, 3000, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x08, 0x01, 0xFF)
    #3001 = #1
    (crc16, 3000)
    (arrclr, 4000, 16)
      M99
    o<rc> endif
    (print,--------)
    M99
    Here is an example of g-code that turns relays on/off one by one in a loop (address of my board is 2):
    Code:
    o<mb_relayalloff> exec [2]
    #<cnt> = 0
    #<onoff> = 1
    o<loop> repeat [160]
      o<mb_relay> exec [2] [#<cnt>] [#<onoff>]
      #<cnt> = [#<cnt> + 1]
      o<chk> if [#<cnt> GE 8]
        #<cnt> = 0
    	#<onoff> = [LNOT[#<onoff>]]
      o<chk> endif
      (print,#<cnt>    #<onoff> )
      G04 P0.1
    o<loop> endrepeat
    Thank you for the reply I'll take a look.
    Frank
    Spark Robotic
    Is it possible to transmit and receive without using
    G65. Inherently if a gcode is running we would not
    Be able to communicate modbus with g65.
    Mar 2017
    1304
    Re: Modbus
    You mean M65?
    You mean M65?
    Yes m65 , g65 was a typo. Are the serial pins directly available
    Outside of gcode.
    Mar 2017
    1304
    Re: Modbus
    Currently not, working on it.
  1. Modbus
    By Maurice1 in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2019, 09:40 AM
  2. UCcnc and Modbus (;-)
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-30-2016, 07:36 PM
  3. Need help with ModBus
    By jharvey407 in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2015, 06:51 PM
  4. Trying to find Modbus commands for Modbus access in VB scripts
    By JoeKumanchik in forum Screen Layouts, Post Processors & Misc
    Last Post: 10-30-2014, 05:54 PM
  5. MODBUS
    By cncbpt in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-07-2013, 06:24 PM
