585,567 active members*
3,547 visitors online*
Results 1 to 3 of 3
    Jul 2021
    9
    Question Homing Problem
    Hello, I use the MK3/9 card for a lathe, I want to reference the X, Z axes. X is Min, Z in Max. The problem I have is that the Z axis moves in the direction of Max, and then with G0 to Min position. Why is that, thanks Markus
    Aug 2020
    131
    Re: Homing Problem
    what are your settings in
    Programm Options/Home/Move to/Z
    after homing the system moves the axis to the value defined there.
    If you have Set the Z Switch position to 200 (for example) and have the Move To Postion set to 0 (I think thats the default value) it will home on, assume that its on Z 200 and then moves to Z0
    If it should stay at 200 you need to set the Move To Postion for Z to 200 as well
    Jul 2021
    9
    Re: Homing Problem
    Thanks I'll try when I get a chance
  1. Homing Problem
    By garryg in forum Mach Mill
    Last Post: 09-21-2014, 06:59 AM
  2. Homing Problem
    By red_alert in forum LinuxCNC (formerly EMC2)
    Last Post: 08-15-2010, 03:50 AM
  3. Homing problem
    By airtime in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2010, 11:27 AM
  4. X4+ homing problem
    By rzmac in forum Syil Products
    Last Post: 03-16-2010, 05:10 PM
