585,668 active members*
4,051 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 10 green start button
Results 1 to 10 of 10
    Dec 2005
    114
    Hey Everyone:
    Powering up - push the green start button, relays pull down control comes on, machine is basically operational.
    Release the green button, relays kick out. Power supply low voltage? Check method?
    Dec 2013
    5717
    Re: VMC 10 green start button
    Quote Originally Posted by Sprew View Post
    Hey Everyone:
    Check the stop button. It may not be making contact properly, not an uncommon condition.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2008
    1632
    If you're talking about the green power button at the back of the machine then look at K1.
    K1 is a latching relay. When you push in the Green power button it allows power to the dc power supply. The DC power supply powers up and energizes K1. K1 has a set of Normally Open contacts that Latch and keep power going to the power supply until you turn off the main disconnect switch.
    Hey Everyone:
    Oct 2008
    1632
    Sorry, I failed to mention that you need to have a good 5 volts from the power supply in order to energize K1. Have someone hold the button in and go measure your voltage at the power supply 5+ VDC to ground. If that's good then you probably have bad contacts on that relay.
    K1 is a relay mounted on the power supply according to the drawings.
    Dec 2005
    114
    Yes, the green button in the back of the machine.
    Thank you for the replies and drawings. Will take a look and see if that works.
    Dec 2005
    114
    K1 Relay was it! Thank you.
    Had a old 4020 sitting out in the yard. Pulled the relay from that and it worked like a charm.
    BTW: I am in So Cal. Anyone needs a '85 4020, come pick it up.
    Have a good weekend!
    Oct 2008
    1632
    Good deal. Thanks for the follow up.
    Feb 2005
    750
    What is wrong with the 4020? Do you know the footprint, approximately? I'm in South Orange County.
    Halfnutz
    Oct 2008
    1632
    Approximate size is a 10 foot cube weighing in at 10,500 pounds and takes 3 phase power unless you get the single phase transformer.
    All the documentation is online. Google Fadal 4020 Dimensions.
    It's 115" wide, it's only 87" deep, but you need to allow 3' in order to open the cabinet doors and to remove the y axis ball screw.
    Height depends on extend Z axis or not. I believe with the extended it takes about 9.5' to operate.
    I don't know anything about it than it's missing a K1 Relay
    Quote Originally Posted by Halfnutz View Post
    - - - Updated - - -
    Dec 2005
    114
    ha ha yes I will put the relay back once I get the new one.
    Halfnutz - nothing wrong with it when I unplugged it. Just don't have the room. Breaking my heart to see it sit. Needs a good home.
    I think a couple of the amplifier cards are new style. Anaheim.
  1. Start Cycle Button
    By wsj in forum Mach Mill
    Last Post: 06-25-2019, 03:36 PM
  2. Laoded my first program, hit the green button...
    By l u k e in forum Haas Mills
    Last Post: 03-26-2011, 02:39 AM
  3. The Green button won't go :-\
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2009, 11:29 PM
  4. the green button
    By msn_jrd in forum Tormach Personal CNC Mill
    Last Post: 07-20-2008, 04:02 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
