585,997 active members*
5,068 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Output Board and Adapter for limit switch on MK3: remaining signals?
Results 1 to 6 of 6
    Nov 2021
    35
    Question Output Board and Adapter for limit switch on MK3: remaining signals?
    Hi everyone,
    I've a question: I've a MK3 board and I've bought a Output board for my spindle, and there are on it, more the PWM signal, three relè output.
    How I can use the other output of the board? (I lost 4 outputs, in this way)
    The same for the Adapter for limit switch: there are on the board 4 input, and the other 4?
    (There are in total 8 inputs and 8 inputs on MK3 board, and only 4outputs and 4 inputs on the additional board...)
    Thank's in advance
    Nino
    Mar 2017
    1312
    Re: Output Board and Adapter for limit switch on MK3: remaining signals?
    You can make a simple splitter. Something like this:
    https://planet-cnc.com/product/split...put-connector/
    Nov 2021
    35
    Ok, thank's.
    The same is for Adapter limit switch board?
    I have to buy another output board o I can use directly the output of the main board?
    Also, I must another Adapter limit board or I can use directy the other input from the main board?
    Nino
    Nov 2021
    35
    Quote Originally Posted by Clyde_IT View Post
    Ok, thank's.
    Nino
    through the splitter, of course...
    Mar 2017
    1312
    You can use inputs/outputs directly from main board. Just make sure you don't draw more than 20mA from outputs. And optoisolation is highly recommended for inputs.
    Nov 2021
    35
    ok, thank's again
    Nino
  1. Replies: 1
    Last Post: 10-12-2020, 09:23 AM
  2. Replies: 5
    Last Post: 08-14-2019, 03:32 PM
  3. Mk3 output board not working?
    By MrEmo in forum PlanetCNC
    Last Post: 01-26-2018, 03:59 PM
  4. cheap limit switch board
    By dertsap in forum DIY CNC Router Table Machines
    Last Post: 09-07-2007, 07:08 AM
  5. R90LIM Limit Switch Board
    By cncadmin in forum News Announcements
    Last Post: 05-23-2004, 04:20 PM
