585,752 active members*
4,213 visitors online*
    Oct 2018
    101
    KITAGAWA USA ?
    hi i was wondering if someone could explain the difference AMONG the kitagawa USA
    Kitagawa Japan and Kitagawa UK
    i think there is Kitagawa Europe?
    i am buying a used B208 chuck and i can't find a" japan" kitagawa so i thought i'd ask yeah? my draw tube takes a M60 x 2.0
    let me know thanks
    Mar 2009
    1982
    Re: KITAGAWA USA ?
    Kitagawa Japan is here
    Do you think knowing the difference helps you with your second hand purchase? Kitagawa local representatives work at local work hours and speak local language. If you call Kitagawa Japan it may appear they out of office and the boy you need to speak with doesn't knows English good enough.
    Don't forget the adapter. Thats the flange between your chuck and spindle nose.
    Oct 2018
    101
    Re: KITAGAWA USA ?
    Quote Originally Posted by Algirdas View Post
    yes you are correct but what about it? is kitagawa UK the same as Kitagawa japan?
    same bore thru hole ? same thread size ?
    Apr 2009
    1262
    Re: KITAGAWA USA ?
    As far as I know, there are no differences in the chucks. A B210 is a B210 no matter what country it is from.
    Experience is what you get just after you needed it.
  1. Job Vacancies In USA For Engineering Graduates www.engineeringjobs-usa.com
    By engineeringjobs in forum Employment Opportunity
    Last Post: 08-04-2012, 09:01 AM
  2. Engineering Jobs In USA engineeringjobs-usa . com
    Last Post: 04-23-2012, 10:59 AM
  3. KITAGAWA ON SL-10 HELP
    By ChsBrown in forum Haas Lathes
    Last Post: 07-19-2009, 06:16 AM
  4. Kitagawa B-12
    By petriej in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2007, 12:02 AM
