https://www.youtube.com/watch?v=rXXhWENh-DA
Product Link:
https://www.automationtechnologiesin...h4-750w-3-axis
EtherCAT Servo Motor Control System with Mach4, 750W, 3 Axis
You can add a AC EtherCAT Servo Motor, Driver, Cable for 4 , 5 6, more axis
No Power Supply, No Breakout Board are needed, Easy to wire
Following Items are included:
-- 1 Pcs Rebuilt Computer with 19 inch Monitor: 8GB of RAM, 500 GB Hard Drive, Windows 10 Pro x64 with One Year Warranty, If you need a brand new Computer, We can update to a new Industrial Computer for you
-- 1 Pcs Mach4 CNC EtherCAT Software, License ( You can choose different Mach4 Screen) from Artsoft software
-- 1 Pcs Kingstar’s RTX64 Runtime License and KINGSTAR EtherCAT License ( You do not need any Breakout Board, Ethernet board any more) from KINGSTAR
--3 Pcs EtherCAT Servo Motors 750W
Model Number: 750W ELM0750LH80F-SS
-- 3 Pcs EtherCAT Servo Driver
Model Number: ELP-EC750Z
-- 3 Pcs Cable-7BMA5M0-Z "5-Meter encoder cable with battery"
-- 3 Pcs CABLE-RZ5M0-S - 5-Meter power cable
EtherCAT Servo Motor Kit, 750W 220VAC (750W EtherCAT kits with 5meter cable)
If you need 3 Meter cable, pls let me know. (Cable-7BMA3M0-Z "3-Meter encoder cable
with battery" , CABLE-RZ3M0-S - 3-Meter power cable)
-- 3 Pcs Proximity Switch with 1.5 Meter Cable
-- 1 Pcs E - Stop with 1.5 Meter Cable
-- 1PCS 12Vdv Power Supply for the limit switch
We can configure 4 Axis, 5 Axis, 6 Axis ..... to N axis
We can change from 1.5-meter cable to other Length as you need
