586,011 active members*
4,215 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to disassemble Chinese BT30 Spindle
    Apr 2021
    8
    Hello all, I need some help here.
    Just received my BT30 spindle from Aliexpress today and I have plans to change out the stock bearings with higer speed ones in few weeks time.
    The problem is I can't seem to unscrew the nut on the drawbar assembly using a wrench. Do I need a specialised tool for that nut?
    Attached is a pic of the mentioned nut in the yellow box.
    Thank you in advance for any help!
    Mar 2014
    1131
    Re: How to disassemble Chinese BT30 Spindle
    It is threaded I think. Does it not have flats to fit a wrench?
    Sent from my MI 5s Plus using Tapatalk
    Apr 2021
    8
    Quote Originally Posted by Azalin View Post
    I just figured it out. The collar below the nut needs to be removed first by loosening the grub screws on it's side.
    Next, loosen the 3 grub screws on the pulley to get it off the spindle shaft, and then I have access to the bolts on the cap below.
    I'll figure out the rest later today.
  1. ATC Spindle Assembly using a Chinese BT30 Spindle Cartridge
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2020, 08:31 PM
  2. Chinese BT30 Spindle Upgrade
    By LBDesign in forum CNC "do-it-yourself"
    Last Post: 05-05-2020, 10:34 AM
  3. Chinese BT30 Spindle
    By NotASandwich in forum Vertical Mill, Lathe Project Log
    Last Post: 04-24-2019, 03:18 AM
  4. Replies: 3
    Last Post: 01-06-2018, 12:43 AM
  5. Chinese ATC Water Cooling Spindle with BT30 Tool Holder
    By Roctech-Cathy in forum Roctech CNC Routers
    Last Post: 01-17-2016, 01:05 PM
