585,754 active members*
3,961 visitors online*
    Dec 2015
    41
    Z Axis Troubles
    Ok here goes. I posted about problems with this before I'll start at the beginning.
    The machine is a Kiwa Excel center-4 built in 1984. The control is Fanuc 3m model c. The z servo motor is Fanuc Dc 10m.
    I was running a simple program the day this started. Countersinking some parts nothing special. I went to shut the machine off after running a while and I always had to handwheel the z down on a prop board so the head doesn't drop when the machine is off. I was handwheeling the z at a slow increment and it jumped down about a half inch. It got alarms but I don't remember exactly what they were. I reset the alarm and ran the program over. It was ok running in auto. In handwheel it dropped in the z again. I think at this point the watchdog alarm led lit on the motherboard. I turned the machine off and when I went to restart later it never came back on. The fanuc manual says if you get a watchdog alarm to replace the main board. I then bought a used motherboard off of ebay. I transferred everthing in sockets to the ebay board. After putting all the boards back in I re-entered all my parameters. After that the machine started with only a servo error 34 ( z feedback cable is disconnected). I did successfully start the machine up with no error 1 time and homed it. While it was sitting with the spindle running I heard click got the servo 34 alarm again.I then took the z motor off and took it apart to clean it out and found oil from the gearbox below it inside the motor. I cleaned the whole motor with QD electronic cleaner let it dry and put it back together. After putting the motor back on I discovered if I warm the motherboard around the z encoder plug it will come up with no servo 34 error. When I try to start the servos the z tries to slam in the minus direction into my prop board before the servos shut off. The z drive then throws an OVL alarm on the front of the drive. I have tried another drive since this started happening with no change. I'm trying to figure out what to do next.
    Dec 2013
    5717
    Re: Z Axis Troubles
    Sounds like a bad solder connection around the Z axis encoder connector. And maybe the encoder input is inverted from the original, this also could be a parameter setting. That may be why it is slamming into the prop board. Really sounds like the encoder and motor are not in agreement as to direction.
    Now what I would do is remove the entire control system and replace it with a Centroid or Dynomotion system. But I have a very low tolerance for antique controls.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1570
    Re: Z Axis Troubles
    ...check the Z axis motor Tachometer.....dirty or failing older DC Servo Tach's can cause ruff, jumpee or a Overload condition to occur during axis movement.
    Dec 2015
    41
    Quote Originally Posted by machinehop5 View Post
    I removed the z axis motor from the machine and laid it over on its side. I took off the motor cap and encoder cap. With an oscilloscope I checked the voltage to the encoder it was 5 volts. The B- and B connectors both had a positive square wave that increased the faster I rotated the shaft. Z gave 1 positive pulse per rev. Z- Gave 1 negative pulse per rev. A and A- gave a positive square wave that changed with rotation speed. The encoder is model A860-0300-T001 2000p.
  1. Troubles dialing in A axis
    By CricutDude in forum Machines running Mach Software
    Last Post: 08-12-2014, 04:59 PM
  2. Please take a look. 5 axis TB6550AHQ motor troubles.
    By steve.mussared in forum Chinese Machines
    Last Post: 04-18-2012, 03:42 AM
  3. Z Axis troubles
    By Arkwhizzard in forum LinuxCNC (formerly EMC2)
    Last Post: 09-02-2009, 11:15 PM
  4. Z axis troubles
    By DSL PWR in forum Waterjet General Topics
    Last Post: 07-22-2007, 05:25 PM
