585,880 active members*
6,015 visitors online*
    add stepper motor
    on my 3d printer i was able to piggyback a stepper on the z axis for better resolution. thets say you have a 3 axis board and need a dual steeper setup to control both sides of the gantry, can you do the same and run two longs as they didnt max the v/a?
    Nov 2008
    644
    Re: add stepper motor
    Not sure what two longs means but I recommend you search images for: wire two steppers serially
    Jan 2022
    5
    stepperonline has a lot of suitable inexpensive stepper motors.Some customized services are also available.
    https://www.omc-stepperonline.com/hybrid-stepper-motor/
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
