585,752 active members*
4,236 visitors online*
    Sep 2020
    18
    Fanuc 3M Drip Feed
    We finally have a somewhat decent post processor for our Fanuc 3M Accumill. But now that we can create much more complex (and sub sequentially larger) programs, our little old 3M is running out of memory. I can only store an estimated 16kB, not nearly enough for our complex programs.
    So I want to drip feed to the control. I looked up others trying to do the same thing but is seems few have come to a conclusion. I see some buying expensive extra hardware, but I don't want to go down that road unless absolutely necessary. Our control has a tape reader along with a mysterious black box behind the panel (see images). I wonder if this could be some kind of adapter for drip feeding? We have a laptop wired in via RS232 directly to the back of the tape reader just to load programs. Was the tape reader meant to only load into memory? Or was it used to drip feed and execute directly?
    IMAGES: https://flic.kr/s/aHsmXeGRka
    Justin
    Dec 2015
    41
    Re: Fanuc 3M Drip Feed
    I have a 3m and have been drip feeding it for years. My setup required buying the 8 chips from Memmex in Canada. They are the ones under the black CPA plug on the top of the motherboard. They were expensive but all I have to do to switch from machine memory to drip feeding thru the rs232 port is hit the e-stop and change the I/O parameter to a 1. If you plan on using alot of long programs it might be the way to go. Just for a side note the display doesn't show the program while running in drip feed mode. The program has to be read from the pc screen. Hope this helps some. Dan
    Sep 2020
    18
    Do you know if they have a website or some place we can order them? are they still around and about how much did the set of new chips run you?
    Justin
    Dec 2015
    41
    Quote Originally Posted by WakelessFoil View Post
    Justin
    Try one of this number.
    Memex Inc.
    Burlington, On L7n 3v6 canada
    905-635-1540
    Ask for
    Wayne McPhail.
    Apr 2009
    1379
    Wayne McPhail. left years ago.
    New address:
    880 Laurentian Drive – Unit #2
    Burlington, Ontario L7N 3V6
  1. fanuc 10m drip feed
    By tazbierzych in forum Fanuc
    Last Post: 09-19-2020, 01:29 PM
  2. Drip feed on a fanuc O-M
    By Jmorris in forum Fanuc
    Last Post: 08-13-2013, 02:34 PM
  3. Fanuc OM Drip Feed
    By danSN in forum Fanuc
    Last Post: 01-03-2012, 03:45 AM
  4. Drip feed for Fanuc 0-MF
    By giorgis in forum Fanuc
    Last Post: 05-08-2009, 04:44 PM
