585,975 active members*
4,520 visitors online*
Thread: Slow feed
Results 1 to 2 of 2
    Slow feed
    I mostly cut P20 toolsteel on my Fanuc EDM. The problem I am having is that whilst trying to cut a piece 60mm thick the feed rate is painfully slow. What can I do to make it go faster?
    Jun 2015
    4154
    Re: Slow feed
    just kidding, but one way to look at this is to be proud that it takes 60mm thickness without breaking the wire
  1. Does feed slow if spindle slows?
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 07-01-2013, 01:03 AM
  2. Loud noise on slow feed?
    By itko in forum Uncategorised MetalWorking Machines
    Last Post: 05-09-2013, 10:07 PM
  3. Feed rate slow down
    By gtdinc in forum Fanuc
    Last Post: 04-30-2011, 11:49 AM
  4. Y axis groans with slow feed ?
    By kojack in forum Haas Mills
    Last Post: 08-15-2009, 07:47 AM
  5. Feed motion is too slow
    By stephan2508 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2009, 06:27 PM
