586,005 active members*
4,975 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > control rotating indexing table with 3PH motor
    Dec 2006
    130
    Hi all, how do i control stop and go function of the rotating indexing cam table that includes the 3PH motor with brake with VFD.
    Can I program the motor to brake once it reach the position without stopping the frequency speed of motor.
    Will this cause the motor or VFD to heats up?
    Or should I brake and stop the VFD upon position, and release brake and start VFD to move to next position.
    But this method will have a slow start up..
    Dec 2013
    5717
    Re: control rotating indexing table with 3PH motor
    Quote Originally Posted by Syphonics View Post
    This will damage the motor or VFD
    This is the proper way to do it. You can most likely set the acceleration to 0.1 second, almost instantaneous.
    The better method would be to control the rotary with a servo motor rather than a 3 phase motor and a VFD.
    Jim Dawson
    Sandy, Oregon, USA
  1. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
  2. good VFD for bridgeport s1, 3ph in 3ph out?
    By Prl motorsports in forum Phase Converters
    Last Post: 11-12-2011, 09:57 PM
  3. Testing an AC 3ph motor
    By bigalow in forum Phase Converters
    Last Post: 03-14-2008, 03:58 AM
  4. Convert 440 3ph to 220 3ph
    By jstrayer in forum Community Club House
    Last Post: 12-28-2007, 04:44 AM
  5. 208V 3ph machine on 240V 3ph?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 11-22-2006, 01:34 AM
