586,011 active members*
4,568 visitors online*
    Sep 2015
    12
    Stepper and pid
    Hi guys,i have some questions. I have a personal project in wich i must have a stepper motor that can be manually controlled(rotation and speed), and i have to integrate a pid with a heater and a thermocouple or thermistor to show on the same display. It should look something like this:see attachment
    One "button" to controll/set the temperature, and one for controlling the stepper. Wich is the cheapest way to achieve this? Temp max about 300C°
    I know i can use a pid and stepper with drivers, but i want to have both on the same display. Also i know about ramps 1.4 with arduino mega, but not sure i can controll the stepper mannually without a gcode. Any sugestions are welcomes. Ps i am not quite an expert on this. Thank you!
    Nov 2013
    4372
    Re: Stepper and pid
    a plain stepper is incompatible with a PID control.
    PID control requires feedback from the controlled device....and a plain stepper has no feedback. If you attached an encoder then you will be closer....but
    a stepper requires Step/Direction type inputs whereas servos for which PID controllers are ideally suited, are analogue.
    An Arduino will make a perfectly fine Step/Direction controller which will turn the stepper backwards and forwards no trouble...but OPEN LOOP.
    If you really want CLOSED LOOP that can be done but is way more complicated.
    Craig
    Sep 2015
    12
    Craig
    Thanks for the answer, but i think i didnt explain correctly. I dont want the motor to be controlled by the pid. I just want manual control of the motor, but on a display to show the speed of it. And also with the temperature, separate button to set/controll the temperature, and shows the actual/set temp on the same display. I just want somehow to show both on the same display.
    Mar 2015
    409
    Re: Stepper and pid
    The easiest (still not easy) is a 3D printer controller running Marlin. Marlin has a build-in PID contoller, can measure temperature (extruder), can run a stepper and is capable of displaying information on a display.
    For just controlling the speed and direction of a stepper you could use this:
    https://nl.aliexpress.com/item/33045...bf6b215129a768
    The cheapest way is using an arduino Uno board and a step-stick driver board or and arduino Mega and a Ramps 1.6 board and some kind of i2C display. In both cases you have to develop the software you self. For that you can use the arduino examples and combine several examples to a working program. For a novice, tt will take quit a long time to get it done.
    Mar 2009
    1982
    Re: Stepper and pid
    in my understanding there is nothing related to PID. Right?
    Only you can decide what is the cheapest way. For me the cheapest solution is if I take a hardware from my shelf and start the design instantly.
  1. Vectoring PID
    By DC67 in forum Spindles / VFD
    Last Post: 06-04-2020, 06:53 PM
  2. Pid settings
    By Larsjo in forum Stepper Motors / Drives
    Last Post: 04-16-2020, 11:43 AM
  3. Can you tune the PID controller on HSS86 closed loop stepper driver?
    By men8ifr in forum Stepper Motors / Drives
    Last Post: 03-25-2019, 11:44 PM
  4. Controlling one PID controller with a second PID controller
    By Dave in forum Servo Motors / Drives
    Last Post: 08-02-2015, 02:51 AM
  5. Pid
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-04-2004, 08:22 PM
