585,930 active members*
3,984 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 2.2kw Spindle Connector - I need a new 4 pin plug
    I just purchased a Chinese 2.2KW water cooled Spindle. I need a new Female 4 pin Aviation Connector and I'm having no luck finding one. I've purchased 3 different ones and none fit, they look similar but just a mm or two off. Please let me know a proper part name & # or a link to get a replacement. Thank you!!!
    Nov 2013
    4371
    Re: 2.2kw Spindle Connector - I need a new 4 pin plug
    can you change the socket and the plug as a pair? Chinese plug/socket combos tend to be cheap nasty affairs at best.
    Craig
    15362
    Quote Originally Posted by originalsigns View Post
    Direct Wire, using an EMI Cable Gland restraint, they come in many different types of shield clamping, this is important part that these, 4 pin connectors don't offer.
    Just some snip of some EMI Cable Restraints
    Mactec54
    OK - I finally found the proper connector. https://buildyourcnc.com/item/spindl...ector-threaded These guys area fantastic to work with.
    Nov 2014
    724
    I upgraded mine to an Amphenol connector right off the bat during the build. They just are sturdier and more robust.
    Attachment 473460
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  1. Plug and Play 2.2kW Spindle --- Worth the upgrade?
    By Joseph_Crowe_DIY in forum Avid CNC
    Last Post: 08-25-2019, 07:49 PM
  2. Connector pin specs
    By yugami in forum Milltronics
    Last Post: 01-17-2019, 04:20 PM
  3. 2.2kw spindle, which pin is ground?
    By QuinnSjoblom in forum Spindles / VFD
    Last Post: 04-15-2018, 12:11 AM
  4. 10 pin connector help
    By Rees Guitars in forum Controller Cards
    Last Post: 01-20-2008, 07:29 AM
  5. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
