585,956 active members*
4,617 visitors online*
IndustryArena Forum > CAM Software > CamWorks > random scratches and wrinkles when generating a toolpath
Results 1 to 7 of 7
    Aug 2020
    8
    hi
    i'm experiencing a frustrating problem with camworks , sometimes it randomly
    generate crapy toolpath with no reason (as shown in attached photos) ,
    my only option would be to create a freash new file
    with the same part in it, and redoing all my cam operations exactely identical to the first file and regenate the toolpaths
    to get it perfect and smooth.
    before redoing all my work in a new file, i've tried everithing ,
    i tried deleting the faulty operation many times and recreated it, i tried changing all different parameters with the feature,
    i tried receating a different feature with new operation , but nothing will change the bad toolpath result unless i start over with a new file in solidworks
    wich is time consuming and frustrating ,
    please any suggestion if anyone experinced something similar
    thanks
    Jun 2015
    12
    Re: random scratches and wrinkles when generating a toolpath
    Can you send the file?
    Aug 2020
    8
    sure, please check attached file,
    i've deleted all irrelevent operations and left the faulty one to reduce file size.
    i'm using solidwokrs 2020 with camworks 2021
    Mar 2008
    683
    Did you cut an actual part? Sometimes the simulated results just suck.
    Aug 2020
    8
    not just the simulated results, also when checking the toolpath in NC editor you can clearly see curly wrinkly toolpaths as shown below
    Jun 2015
    12
    I am using Solidworks 2020 but Camworks 2020 so the cam data did not open. I have noticed that unless all the service packs are in there is always a lot of issues with camworks software. That’s why I never install the software unless it is at least SP5. If you have CW2020 on your system try running the same toolpath parameters with that and if you get the same results zip and attach that file. Also in camworks options what do you have your Facet deviation and spline deviation set at? In the operation parameters on the “finish tab” what do you have the avoid allowance and mach deviation set to?
    Aug 2020
    8
    avoid allowance is set to 0
    mach deviation is set to global mach deviation 0.01mm
    facet deviation 0.01mm
    spline deviation 0.03mm
  1. Mach 3 hangs while generating toolpath
    By jet8300 in forum Machines running Mach Software
    Last Post: 11-08-2021, 08:30 PM
  2. Mach3 PostProcessor generating crazy toolpath. (huge circles)
    By carmamir in forum Post Processors for MC
    Last Post: 02-05-2014, 02:24 PM
  3. 3D milling toolpath generating unwanted paths
    By Ariel6789 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-05-2011, 11:48 PM
  4. 2d random toolpath issue
    By rich_cree in forum Vectric
    Last Post: 07-24-2009, 12:35 AM
  5. Toolpath Group posting generating several NC Files
    By mattford1 in forum Mastercam
    Last Post: 05-31-2007, 01:26 AM
