586,009 active members*
4,973 visitors online*
    Retrofitting Old Kitamura
    Theres a Kitamura Mycenter 1 and Mycenter3b near me that i can get dirt cheap and im thinking about buying one or the other cutting out all the electronics and then adding new ones.
    Im thinking a UCCNC controller or Masso with step and direction drivers and then replacing the servos with Clearpath. These seem beefy and until i get the machine i wont know size required.
    https://teknic.com/model-info/CPM-SD...lttqmOtJ5qqJpQ
    if i drop 10k into it and i have a modern control and some serious rigidity.... nothing quite out there that can do that for that cost.
    Before i buy this thing and dive in, anyone have any thoughts?
    I know they have Turcite ways but its cast under that, and i was even thinking of removing turcite and adding some beefy linear rails.
    If this thing isnt cutting as deep as it originally did, im ok with that. I still think it would be leagues ahead of something like a tormach 440.
    Dec 2013
    5717
    Re: Retrofitting Old Kitamura
    Seems like a reasonable idea. Certainly something that I would do, and have done. There is no substitute for a massive machine.
    You might look at DMM Tech servos also. Compatible with step & direction, and price comparable with ClearPath with better resolution.
    Rather that replacing the original turcite ways with linear rails, give the machine a try first as it is and see what the results are. You might find it to be OK.
    Jim Dawson
    Sandy, Oregon, USA
    Definitely will, thanks for the feedback Jim.
    Ill post up as i go
    Nov 2020
    361
    Aren't boxways more rigid than linear guides? I think they usually replace boxways with roller guides for the speed gain. If you wanna go cheaper or more torque for the same price there's Lichuan or Wenling Yuhai or CTB.
    What about the spindle? Is there a spindle cartridge in the machine(s)?
  1. bp1 retrofitting
    By jpbrusa75 in forum Bridgeport Machines
    Last Post: 05-23-2021, 11:43 PM
  2. Retrofitting a old Haas?
    By lamtldealer in forum Haas Mills
    Last Post: 04-17-2016, 01:18 PM
  3. retrofitting a km3
    By tjs in forum HURCO
    Last Post: 03-14-2015, 08:13 PM
  4. Retrofitting a Bridgeport
    By kuchean in forum Servo Motors / Drives
    Last Post: 07-24-2006, 07:46 PM
  5. Knee retrofitting
    By m_c in forum Knee Vertical Mills
    Last Post: 02-27-2006, 10:12 PM
