585,883 active members*
4,883 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processors > Aspire 10.5 Mach3 Post Processors
    May 2017
    I'm running cnc mill that is driven by a laptop running mach3 (Nvem 2.1). I used to run vectrix aspire to generate g-code and load them up in mach 3 to run the machine, then zero xyz on the material stock corner bottom left.
    After start, its first moves are right. But then it is offsetting on X and Y axis. I just tried it for one drawing and it offseted everytime at same point. Everytime i am runing same g-code. Sometimes it is offsetting just on Y axis, sometimes X and Y. Sometimes running well.
    I could not understand where is problem. When i was using ArtCam there was no problem such as this. Because of that I suppose to problem is on Post Processors.
    Also I attached screenshot of mach3. You can see clearly start point of wrong direction of mill. I marked with red line start position of offset.
    If anyone have experiance about like that issue can help me to find problem?
    Re: Aspire 10.5 Mach3 Post Processors
    M facing the same problem and almost start to blame the NVEM Card , should I use ArtCAM ?
  1. Aspire and Mach3 doing random things
    By blackdoglaser in forum Mach Software (ArtSoft software)
    Last Post: 02-17-2016, 10:48 AM
  2. Aspire toolpath to Mach3
    By JC50 in forum Aspire
    Last Post: 02-10-2013, 02:57 AM
  3. Aspire and mach3
    By stk2008 in forum Vectric
    Last Post: 01-28-2011, 06:31 PM
  4. Bobcad for Mach3 post processors
    By duraflap in forum BobCad-Cam
    Last Post: 10-28-2007, 03:16 PM
