585,906 active members*
3,676 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Amplifier fault on X axis.
    Aug 2007
    29
    Fadal VMC 6030 CNC88HS. Powered up, select 'Jog', amplifier fault message on whatever axis I select. Power down, hooked a jumper on the 1100-1b board,right side of fuses, between 12 and 16 to bypass stop condition. Powered up, 'Jog', select Z and move, select Y and move, select X and 'amplifier fault X axis. Swap axis cards, no change. Had motor rebuilt ($$) no change.
    Aug 2007
    29
    The amp that had initially tested good, now proved to be defective. Replaced it (X axis), and with the rebuilt motor, and alarms were cleared, all axis functional.
  1. fadal servo amplifier fault
    By bala955 in forum Fadal
    Last Post: 06-17-2015, 12:00 AM
  2. Z axis Amplifier Fault on Fadal 4020
    By Fudd in forum Fadal
    Last Post: 08-29-2006, 11:01 PM
  3. Z Axis Drive Fault
    By jeremy_d in forum Servo Motors / Drives
    Last Post: 08-16-2006, 04:04 AM
  4. C axis fault
    By Rudee in forum Fadal
    Last Post: 05-13-2005, 05:58 PM
  5. Axis Drive Fault
    By Bluey in forum DNC Problems and Solutions
    Last Post: 11-04-2004, 01:54 AM
