585,875 active members*
4,052 visitors online*
Results 1 to 5 of 5
    Dec 2009
    521
    Dyna DM4500 VMC: FREE
    A local club member is moving. He started the restoration of this Dyna Myte DM4500. He can't take it with him.
    The iron is done and ready for a new control. The old controls including spindle drive have been removed and are no longer available. 7.5hp Spindle motor is included.
    The machine is located in Buckeye Arizona. It would have to be hauled off on a hydraulic drop deck trailer, measuring at least 6'x10'.
    There is no forklift on site heavy enough to lift it but it can be rolled on to the trailer on skates.
    IT MUST BE PICKED UP BY NOVEMBER 7 and NO LATER OR IT WILL HAVE TO BE HAULED OFF FOR SCRAP
    The work done to the iron:
    "The way covers were removed while working with the forklift. Not shown are the shroud pieces. It has new x & y axis bearings, motor belts, lube system, paint (now blue, didn’t like red), coolant system/motor re-plumbed, spindle motor is 7.5hp 3 phase. Free for the taking including any parts I have for completing."
    Specs and description of machine including pictures:
    Year of manufacture: Mid 90's
    Table size 17.7" x 30.7".
    Max. table load 660 lb.
    Longitudinal travel (X axis) 20".
    Cross travel (Y axis) 16".
    Vertical travel (Z axis) 20".
    Distance, spindle nose to table (min/max) 3.94"/20".
    Distance, spindle centerline to column 17.71".
    Spindle taper CAT 40.
    Spindle speeds (in two ranges) 60 - 6,000 rpm.
    Automatic tool changer 16 station.
    Spindle motor 7.5/10 hp. (30 min.)
    Electrics 3ph/60hz/220v.
    Dimensions 76"W x 84"D x 96"H.
    Weight (approx.) 7,700 lb.
    Full Enclosure.
    SERIOUS INQUIRIES ONLY. Dean wants to find someone that will finish the machine off. He put a lot of money time and effort into it so far.
    Contact me via PM Directly if interested.
    Marty
    Attached Thumbnails Attached Thumbnails 20211020_081414.jpg   20211020_081431.jpg   20211020_081447.jpg   20211020_081516.jpg
    Dec 2009
    521
    Re: Dyna DM4500 VMC: FREE
    Dean got back with me with a measurement, from the base to the highest part of the machine, is 82"*So it should just make it under a 7' garage door using pipe for rollers. (if you are interested, double check your opening)
    Dec 2009
    521
    Looks like she's going to get scrapped.
    Thanks everyone!
    Marty
    Nov 2012
    363
    What a shame.... I would have loved to have taken it, but I have my own space limitations. Plus, I already prevented another machine from going to the dump (DM4400m). Man, I hate seeing these wonderful old machines being trashed though. sigh. But kudos to you for trying to save it.
    If Dean has any of the old control, I would love to take that, though. I have been trying to work my way through fixing the electronics on the drives and such. I would hate to see him throw that stuff out.
    Dec 2009
    521
    Quote Originally Posted by MrMetric View Post
    Machine was scrapped unfortunately.
    Control was sold long ago to keep another machine going.
  1. Dyna Mechtronics VMC DM4322G
    By MPHRacingMotorsports in forum Dyna Mechtronics
    Last Post: 06-21-2021, 04:08 PM
  2. Dyna DM4500 dead
    By lubodm in forum Dyna Mechtronics
    Last Post: 03-21-2018, 01:09 PM
  3. HELP!!! DYNA MYTE DM4800C VMC
    By ROAD75 in forum Dyna Mechtronics
    Last Post: 10-03-2016, 10:16 PM
  4. 1997 DYNA MYTE DM4800 VMC to Mach3 Conversion
    By JHCHOPPERS in forum Dyna Mechtronics
    Last Post: 12-08-2013, 05:26 PM
  5. Flashcut Dyna DM4400 VMC Conversion WITH toolchanger
    By Marty_Escarcega in forum FlashCut CNC
    Last Post: 08-14-2013, 08:50 PM
