585,996 active members*
4,193 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Turret Not seating after crash
Results 1 to 2 of 2
    Feb 2021
    38
    Anybody have Ideas or anybody had this problem after crash. Machine crash and now my turret will not seat completely down to compress the coolant connect. It seams to be 1/4 to 3/8 from bottom. rotates as seams to sit as normal but not back down far enough to compress on the coolant valve. so it must be not seating down all the way. I also have to hit reset every time I want to rotate the turret now I'm thinking of loosening up the bolts ion the turret and let it self seat maybe its just knocked out of alignment. Any ideas. Thanks in advance.
    Mar 2009
    1982
    Re: Turret Not seating after crash
    Of course it is ouf of allignment now. You can check if your cutter nose goes through the rotation center moving X axis.
    Recall the installation of the lathe. Normally two tapered pins should be taken out after transportation of the lathe. Makes the alignment much easier.
  1. lynx 220 turret crash - advice needed
    By DoosanNewbie in forum Daewoo/Doosan
    Last Post: 08-09-2019, 12:50 PM
  2. Turret problem after crash on Hitachi Seiki HT20-SII
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 07:56 PM
  3. Help with CNC Lathe Turret Problem after crash
    By qualitymachine in forum DNC Problems and Solutions
    Last Post: 06-11-2009, 02:52 PM
  4. Proper seating MT3?
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 10-18-2008, 09:51 PM
  5. SL-20 Turret Not Seating
    By Mike K in forum Haas Lathes
    Last Post: 09-27-2007, 06:23 PM
