585,977 active members*
4,005 visitors online*
Results 1 to 6 of 6
    Jun 2015
    13
    Shielded wire shield connection?
    Hi
    I use shielded wiring in my homemade router build, but I´m not sure where to connect the shielding?
    On SmoothStepper I use DB25 terminals, they have usual GND pins and one marked GND?
    On the Drivers side, do I connect the shielding to the ground wire connection?
    On VFD- U,V,W,E. Do I connect the shielding to earth?
    And yes I know that shielding needs connection on only one side of the wire.
    On cnc metal frame I don´t use any ground connections. Every Nema, Spindle, End switch has its own GND by wire. Is this ok?
    Feb 2018
    40
    Re: Shielded wire shield connection?
    Shields should go to EARTH, not any DB25 GND pins.
    There should be one earth ground point, so route the shields to that point.
    Jun 2015
    13
    Ok. So I have earth on AC voltage and shielding DC wires with AC earth is ok?
    Feb 2018
    40
    Quote Originally Posted by FiveO View Post
    There are some recommendations to connect DC voltage wire shields to DC COMMON
    But most recommendations are to use EARTH.
    Most likely any interference is introduced by AC fields, and even a DC induced spike can be shielded by EARTH.
    Would you want your AC induced interference returned to DC COMMON?
    These are guidelines, bottom line is what is "demonstrated to work". Keep physical distance between AC and DC wires, Don't route VFD wires near any control wires.
    Dec 2003
    24221
    You should have a star point earth GND set up in your enclosure, all grounds including the service earth should be connected to this point.
    Albert E.
    Jun 2015
    13
    Thanks for your suggestions!
  1. Grounding shielded wire
    By bodini in forum DIY CNC Router Table Machines
    Last Post: 07-30-2012, 01:33 PM
  2. Shielded wire question
    By adbradley in forum CNC Machine Related Electronics
    Last Post: 08-17-2009, 05:27 PM
  3. Shielded wire for steppers, or not?
    By JanHenning in forum Gecko Drives
    Last Post: 03-09-2008, 02:29 AM
  4. Shielded wire where should I use it?
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 02-22-2008, 02:59 AM
  5. Source for shielded wire?
    By LeeWay in forum CNC Machine Related Electronics
    Last Post: 03-11-2005, 01:26 PM
