586,000 active members*
4,816 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle motor wiring diagram
Results 1 to 3 of 3
    Jan 2012
    48
    I have a spindle motor with the following motor tag. I'll be using the rating in the box - 230v @ 50 hz.
    Attachment 473540
    The diagram from the cover showing how to jump the leads; seems simple enough.
    Attachment 473542
    Here's where I'm confused. Both the motor on the machine and the spare that came with it are wired like this.
    Attachment 473544
    Obviously it's easy enough to change the jumpers around but neither motor is wired to match either of those two diagrams. If they were wired for high voltage the power should be coming in on the UVW-1 side and the UVW-2 should have the jumpers but as they are, it's reversed. Both motors had those covers and they were both the same. Should I shrug it off, wire it up the way I need it and move on with life or does this hint at a concern I should have?
    Mar 2009
    1982
    Re: Spindle motor wiring diagram
    on the label of your motor 230VAC is for delta (triangle) connection. Means, you need to connect jumpers "three in parallel" way, as drawn in framed picture.
    The motor connection on the last bottom illustration is "star", ( opposite to "delta" ). "Star" connection used by default everywhere because windings are connected in series in regards to applied voltage - less chances of overcurrent.
    Dec 2003
    24221
    Quote Originally Posted by ecdez View Post
    IOW, The method of using either the U2 V2 W2 or U1 V1 W1 for the straps will be identical electrically.
    Albert E.
  1. Stepper Motor Controls Wiring Diagram
    By hachin in forum CNC Machine Related Electronics
    Last Post: 11-29-2023, 05:54 AM
  2. Replies: 0
    Last Post: 05-16-2019, 06:04 PM
  3. Wiring diagram for 24v DC motor to ESS controller
    By masinecc in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-21-2018, 07:52 PM
  4. Trying to ID this Breakout board/Spindle Wiring Diagram
    By Barefootboy4 in forum Spindles / VFD
    Last Post: 12-27-2017, 10:57 PM
  5. ATR Manufacturing MC-40 motor controller wiring diagram.
    By Galane in forum CNC Machine Related Electronics
    Last Post: 06-01-2015, 12:20 AM
