585,599 active members*
3,734 visitors online*
Thread: need a motor
Results 1 to 12 of 12
    Mar 2008
    375
    need a motor
    Hello to everyone,
    I got a hold of this Comet milling maching that looks just like a brigeport, for some reason the motor is just not turning on it just makes a humming sound, but when I spin the spindle it starts only on low gear, does anyone know what can be the problem, or should I just get a new 1.5hp motor.
    Thank you
    Nov 2013
    4347
    Re: need a motor
    is this a single phase induction motor?
    If so it sounds like the start winding is not operating at start-up, possibly the centrifugal switch or start capacitor.
    Craig
    Mar 2008
    375
    Re: need a motor
    its a 3 phase induction motor.
    I dont see any capacitors so maybe like you mention it might be the centrifugal switch
    I'll try checking that next.
    thank you for the quick reply
    Dec 2013
    5717
    Re: need a motor
    A 3 phase motor does not have a centrifugal switch. Are you operating on 3 phase power? And if so is it wired for the correct voltage? The symptoms you describe sound like you are running on 230V but the motor is wired for 460V
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    4347
    Re: need a motor
    its only single phase motors that have the centrifugal switch.
    Have you measured the voltage of all three phases, if you lose one phase the motor will most likely not start and hums like hell.
    Craig
    Mar 2008
    375
    Craig
    So if I loose one phase does that mean i need a new motor.
    Sorry for asking this dum question ????
    Mar 2009
    1982
    Re: need a motor
    you don't need a new motor. Check with multimeter if any of windings is not burned. Better- go to the motor repair ( rewind service ) workshop and ask to test the motor. They have a special stands for 3 phase motor check.
    The burned winding makes stable specific smell.
    Nov 2013
    4347
    Re: need a motor
    lets assume you have lost a phase, it could be simply one blown use (out of three), or a fault in the wiring and/or isolator that causes the loss of a phase.
    Another possibility, and not an uncommon fault, is for one of the three contact pairs in the contactor (effectively a big relay to turn the motor on and off) has failed.
    Its also possible that there is a fault in the motor. There could be a failure to earth of one of the windings which will take out a fuse or fuses in short order. Another less common
    fault is for one winding to develop shorted turns. When this happens the winding still draws current, maybe even more than normal, but does not produce the magnetic field
    it would if it did not have shorted turns.
    If you are unfamiliar with three phase motors I would recommend assistance from an electrician, getting a reliable and credible diagnosis of the fault is the first step. Thereafter
    repair/replacement options will be clear.
    Craig
    Mar 2015
    46
    Re: need a motor
    Greetings,
    I had a similar issue with my three phase mill motor.
    Turns out the forward/reverse switch was dirty.
    Fortunately, the motor repair shop did not charge me to test the motor.
    Cheers,
    Dave
    Re: need a motor
    Quote Originally Posted by cob View Post
    Hello to everyone,
    Thank you
    Is the mechanical parts stuck?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2008
    375
    Re: need a motor
    thank you guys
    finaly figure the problem , and yes it was the forward/and reverse switch that was the problem, thank you very much,
    on another note i will be adding a VFD to this mill it has a 2 hp motor does any one have any sudjestion on what type of VFD is good?
    thans again
    Apr 2004
    5731
    Re: need a motor
    We used a WEG on our Bridgeport, which has a similar-sized motor. It worked okay.
    Andrew Werby
    Website
  1. Replies: 4
    Last Post: 01-24-2017, 11:08 PM
  2. Replies: 0
    Last Post: 11-07-2015, 12:04 AM
  3. Amazing spindle motor upgrade package
    By jcposada in forum For Sale Only
    Last Post: 02-13-2015, 07:03 AM
  4. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
