585,761 active members*
4,045 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 15M WCS doesnt apply and/or gets lost after jog
Results 1 to 6 of 6
    Question Fanuc 15M WCS doesnt apply and/or gets lost after jog
    So I've had 2 problems with the 15M machine and I think they both are related
    #1st being if you are at say G54 X0.0 Y0.0 and you go to jog or mpg and move say Y +6" .
    sometimes the readout will change to Y0.0 where ever its out instead of showing X0.0 Y6.0
    #2 issue that may be related is, sometimes when starting machine
    home x/ y /z > origin > memory > cycle start
    O001
    G90
    G54
    G00 X0.0 Y0.0
    It wont move .. And obsolete will read out all 0000s like it never applied the G54
    Then if you home machine again The absolute will blink to the correct numbers
    Run the program again and it will move to the correct G54 home location
    any ideas ?
    www.wildhorsemfg.com machinist / gunsmith
    accumax with Fanuc 11M , Hitachi seiki 3NE with 6T
    Aug 2019
    145
    Re: Fanuc 15M WCS doesnt apply and/or gets lost after jog
    Does your operators panel have a "ABS" or "Manual ABS" switch? It sounds like the manual absolute function is somehow triggering.
    There is neither of those on this control
    Mar 2008
    285
    G90 = ABSolute Mode is where all moves are relative to the Part Program (WORK) Zero Position
    G91 = INCremental Mode is where all moves are relative to the last move and reset to Zero after each move.
    These Modes can be changed in MDI and by Parameter can be set so that at power-on or RESET; or End of Program;
    will initialize certain G-Codes as Defaults.
    Mar 2008
    285
    Also if you look at the DGN bits you can see if the slides are In-Position. If not In-Position the Control will not
    process any more block of information.
    thanks that kinda of makes sense but I don't think that's not the problem , even with a G90 > G54> G00 X0.0 Y0.0 it will wont always apply the offset or move to there .... but sometimes it will
    Not sure what you mean by
  1. Hitachi Seiki HG500 Fanuc 15M Micon 16 II PLC LOST
    By wilfrid50 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2021, 08:42 PM
  2. Replies: 2
    Last Post: 02-06-2021, 08:23 AM
  3. Path Pilot WCS does not coordinate with Fusion 360 WCS when posting program
    By TrinityAeroLLC in forum Tormach Personal CNC Mill
    Last Post: 05-19-2020, 12:36 AM
  4. FANUC 15M-A PARAMETERS LOST
    By UlisesRosas23 in forum Fanuc
    Last Post: 02-02-2019, 09:11 PM
