585,982 active members*
4,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > NEED HELP ABOUT OKUMA OH-OSP-HMG SYSTEM
    Sep 2021
    43
    HI EVERYONE!
    I AM NEW MEMBER.
    TODAY MY MACHINE WAS HOOKED UP WITH ALARM " NO SUBPROGRAM FILE" BB1: A.MIN, , BB1: . SUB.
    I CAN'T FOUND ANY DOCUMENT RELATE FOR SOLVE IT.
    SO PLEASE KINDLY HELP ME!
    I AM SORRY BECAUSE MY ENGLISH SO BAD.
    I AM LOOKING FORWARD TO YOURS ANSWER!
    BEST REGARDS.
    Dec 2008
    3109
    Re: NEED HELP ABOUT OKUMA OH-OSP-HMG SYSTEM
    #1 - STOP yelling... use lower case to talk
    The control is trying to find a sub-routine file called A.SUB when you PSELECT a new program called A.MIN
    Look at either Programming manual or Operation manual for section on File structure & Sub-Program calling
    Apr 2009
    1262
    The machine tries to recall the last program used when it powers up. If that program has been deleted then it cannot find it and in your case it appears that there was a SUB program being used along with the MIN (main) program.
    Superman is correct so PSELECT a new program and the problem will probably go away. If not the make sure there is no “O” in the file name because Okuma considers them a SUB as in CALL O1234. ….your code … RTS.
    Best regards,
    Experience is what you get just after you needed it.
    Sep 2021
    43
    Thank you so much for your's reply!
    I was tried found the manual of OH-OSP-HMG system but i can't. So please give me more details
    And, if you have the document that relate with my machine please sent for me via my email: [email protected].
    I so sorry about inconvenient.
    Thank and best regards!
    Sep 2021
    43
    Thank you so much for your help.
    Unfortunatetly, my machine was lost all documents relate and Okuma system so fresh with me.
    So, please hlep me more details for how to solve it and sent for me somes document that relate with OH-OSP-HMG system if you have.
    This is my email address: [email protected]
    I am so sorry about inconvenient.
    Best regards.
  1. Replies: 0
    Last Post: 12-19-2021, 04:31 PM
  2. Replies: 0
    Last Post: 04-21-2018, 06:23 AM
  3. Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    By richardtheu in forum Okuma
    Last Post: 08-06-2016, 11:11 PM
  4. Replies: 7
    Last Post: 08-10-2013, 02:25 PM
