585,676 active members*
5,522 visitors online*
    TNC151 handwheel
    Hi there
    My Tnc 151 controller handwheel on milling machine does not work .
    Parameter171 is 0 and handwheel is active in point of software view.
    I can choose the handwheel mode and select axes.
    No alarm occures but no axes movement creates.
    Is it a jumper setting problem? If yes which board ? Which jumper? And how to adjust?
    Best regards
    Majid
    Mar 2016
    323
    Re: TNC151 handwheel
    Do U keep deadmen switch pushed in?
    Quote Originally Posted by steryd View Post
    Hi Dear
    What is deadmen switch and where it is?
    Regards
    Majid
    Hi Dear
    Hanwheel is not remotely it has installed on control panel and no deadmen switch is there.
    Mar 2016
    323
    Then - just guess- it can work in manual not in handwheel mode.
  1. tnc151 problems
    By bobomartin7 in forum HEIDENHAIN -> GENERIC
    Last Post: 11-28-2022, 11:34 AM
  2. heidenhain tnc151
    By bobomartin7 in forum HEIDENHAIN -> TNC
    Last Post: 03-16-2019, 10:18 PM
  3. TNC151 Drip Feed
    By StewCNC in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2009, 03:55 PM
  4. Help with programming of tnc151
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 03-15-2008, 09:07 PM
  5. 3D work on Heidenhain TNC151
    By RedGTZ in forum CNC Machining Centers
    Last Post: 10-27-2005, 02:46 PM
